Circuits questions
Jay2903
PostPosted: 20:59 - 28 Nov 2023    Post subject: Circuits questions Reply with quote
I figured someone here might know the answer to this and have an explanation cos im a bit confused.
(This is an automotive test question)
Using the diagram what are the voltage readings when the wiper switch is moved to the wiper speed two position. The supply voltage is 12v.
Jay2903
PostPosted: 21:04 - 28 Nov 2023    Post subject: Reply with quote
A) pin 4 - 0v , pin 5 - 0v , pin 3 - 12v
B) pin 4 - 12v, pin 5 - 0v, pin 3 - 0V
C) pin 4 - 12v, pin 5 - 12v, pin 3 - 12V
D) pin 4 - 12v , pin 5 - 0V, pin 3 - 12V
Nobby the Bastard
Harley Gaydar
PostPosted: 21:33 - 28 Nov 2023    Post subject: Reply with quote
In position 2 only pin 5 will get voltage and will be 12 v.
Triumph Sprint ST 1050
Jay2903
PostPosted: 22:16 - 28 Nov 2023    Post subject: Reply with quote
I think wiper speed two is number 4 on the diagram.
PostPosted: 22:56 - 28 Nov 2023    Post subject: Reply with quote
None of the above.
Pin 3 only gets power when the washers are activated which isn't mentioned so going by that the only possible answer is B as it's the only one with 0v on pin 3.
Wiper speed 2 is position 4 which puts 12v to both pin4 and pin5 so going by that the only possible answer is C.
MCN
PostPosted: 02:12 - 29 Nov 2023    Post subject: Re: Circuits questions Reply with quote
Is this for a crash helmet visor wiper system or wot?
WD Forte
PostPosted: 02:17 - 29 Nov 2023    Post subject: Reply with quote
It's a poorly written question IMO
If we assume the low points ( switches) all share a common ground as looks likely
and assume the upper pins ( 3,25,4,5) are all at 12v for arguments sake
then in position 2:
pin 3 will stay high (12V)
pin 4 will stay high (12V)
pin 5 will be pulled low (0V)
so answer D
bikers smell of wee
PostPosted: 06:32 - 29 Nov 2023    Post subject: Reply with quote
then in position 2:
so answer D
Hmm, well if you presume that 12v is fed from the top then the correct answer is a because motor speed 2 is switch position 4.
Question setter still needs a slap mind.
Jay2903
PostPosted: 09:23 - 29 Nov 2023    Post subject: Reply with quote
I’ve got the whole diagram now.
Jay2903
PostPosted: 09:30 - 29 Nov 2023    Post subject: Reply with quote
I thought
Pin 5 - 12v
Pin 4 12V
Pin 3 - 0V
But that’s not an option.
Jay2903
PostPosted: 10:33 - 29 Nov 2023    Post subject: Reply with quote
Oh my bad A
Pin 5 - 0v
Pin 4 - 0V
Pin 3 - 12v
WD Forte
PostPosted: 16:20 - 29 Nov 2023    Post subject: Reply with quote
Its feckin D!
pin 5 is obviously pulled low in position 2 so wil be low/0V
pin 4 remains open circuit so high/12v
pin 3 remains open circuit so high/12v
Its still a shit question as the pins are connected not to a 12v supply
but to the emitters of transistors
Unless these transistors are turned on by a voltage at their bases, you could easily argue the voltages at the emitters(pins)are all floating/indeterminate subject to leakage current.
the 15's look like current limiting resistors between each collector
and the 12v power rail
the arrows will go high when the tranny is off and low when on and the emitters connected to ground
The poorly written question forces us to assume they're all turned on so in that case D
bikers smell of wee
PostPosted: 18:42 - 29 Nov 2023    Post subject: Reply with quote
WD Forte wrote:
Its feckin D!
It's not switch position 2. It's motor speed 2 which is switch position 4.
WD Forte
PostPosted: 19:05 - 29 Nov 2023    Post subject: Reply with quote
What?
bollox
As I have comstantly maimtained, its A, hi-lo-lo then
Whistle
bikers smell of wee
jeffyjeff
PostPosted: 20:14 - 30 Nov 2023    Post subject: Reply with quote
Let's write a test question that looks simple at first blush. After reading it for the sixth time you realize that your knee jerk conclusion is way off the mark. Then let's omit the correct answer from the test, just to screw wit the little fuckers. That's the way to do it.
The last post was made 2 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 83.78 Kb
