| jeffyjeff |
 jeffyjeff World Chat Champion
 Posted: 13:01 - 10 Dec 2023 Post subject: |
Try sanding a slight chamfer on the leading edge of the pad material.
EDIT: Also hold the brake on as you tighten the wheel spindle (and anti-torque arm if fitted) so it gets locked down with the pads central in the drum. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
| MCN |
 MCN Super Spammer
 Posted: 19:43 - 10 Dec 2023 Post subject: Re: YBR Drum Brake Squeal |
| jeffyjeff wrote: | 2015 YBR 125, 18,000 km. I am the original owner. Rear drum brake has developed an annoying squeal on deceleration, approximately from 5kph> 0. I disassembled the brake, blew it clean with compressed air, sanded the drum and the shoes with 100 grit sandpaper (longitudinally), then blew it clean before assembly. The annoying condition remains. I've rebuild drum brakes on automobiles that had primary and secondary brake shoes, so I was careful to assemble the shoes in their original locations (although I could find no indication that the YBR brake pad compounds are different top to bottom).
Brake shoes looked good; light glaze that easily sanded off, and no foreign material embedded into the brake pad material. Contact points to the cam and anchor pin appear to be free of abnormal wear or apparent damage.
Not really clear on the next steps to take, other than to replace the brake shoes with new. Anybody on BCF have suggestions on what I could try next before installing new shoes? |
I'd be more concerned with the side effects of blowing out brake dust.
Don't fukaboot and get new shoes,. They're cheap as and your into the elimination stages now. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| blurredman |
 Posted: 10:42 - 11 Dec 2023 Post subject: |
Yes, rubbing away at the edge can help- as well as centralising the shoes in the wheel. Not a big issue to push the brake lever and tighten up the spindle at the same time.
Although brake dust is an issue, at least it won't be asbestos stuff anymore. I had to modify my original pads from my 1980 car (remove the squealer) and I was careful of that. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| Kentol750 |
 Kentol750 World Chat Champion
| jeffyjeff |
| jeffyjeff |
| MCN |
 MCN Super Spammer
 Posted: 16:10 - 12 Dec 2023 Post subject: Re: YBR Drum Brake Squeal |
| jeffyjeff wrote: | | MCN wrote: | ...Don't fukaboot and get new shoes,. They're cheap as and your into the elimination stages now. |
Sorry mate, it's my nature to fukaboot and tinker around until my wife starts to yell at me. Most of the time I don't know what the hell I'm doing, but sometimes I know enough to be dangerous. You're absolutely right, of course. At 10 quid, a new set of brake shoes is easily within budget; but I would prefer to dick around a bit first. You know, maybe grind a perfect arc on the brake cam, or design a roller bearing anchor pin. My dream is to design some useless mod that will challenge BMW engineers for stupidity, and maybe permanently disfigure my motorcycle in the process. Alas, my wife will probably start yelling at me before I reach that level of achievement.  |
It may be biting off more than you can chew at this stage but if I were you, I'd read up a bit on Power Bands Principles and mibby consider installing a couple of them.
(Get the brakes fettled first mind. Safety.)
| jeffyjeff |
There is a gap of 296 days between these two posts... |
| jeffyjeff |
The last post was made 2 years, 42 days ago. Instead of replying here, would creating a new thread be more useful? |
