What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 46, 47, 48 ... 57, 58, 59  Next
Easy-X
PostPosted: 10:30 - 31 Dec 2023    Post subject: Reply with quote
"Yeah, actually a speedo would be nice" Smile
And... no speedo drives on either of the funky wheel hubs Rolling Eyes
DaddyStu
PostPosted: 21:11 - 01 Jan 2024    Post subject: Reply with quote
Checked and prepped mine for another week of stormy commutes.
50mph wind tomorrow so will tie it to the fence at work.
At least it isn't cold though!
Daddystu
Zontes 125-G1 (part-ex'd). Yamaha Tracer 700.
A100man
PostPosted: 10:40 - 02 Jan 2024    Post subject: Reply with quote
Easy-X wrote:
Finishing off a project Triumph that's passed through several hands. Anachronistically it has billet cut yokes and swing arm but the original agricultural engine (this ones gear shift on the right) and oil reservoir in the hollow frame.
What model is that?
Easy-X
PostPosted: 14:28 - 02 Jan 2024    Post subject: Reply with quote
A100man wrote:
What model is that?
Hard to say at this point what it started as but I'd guess an early '70s T140 as the loom's positive earth and shifter on the right. Probably '73 or '74 as I'm fairly sure it's 750cc. Disk brake up front and drum at the back matches up as well but I don't think the bike's rolling with the original wheel hubs.
Basically I'm working on an unfinished project from a friend who bought it as an unfinished project... oh dear Smile
DaddyStu
PostPosted: 00:00 - 12 Jan 2024    Post subject: Reply with quote
Not the bike exactly but proofed all my gear on the washing line while the sun was shining. Used up nearly 5 litres of the stuff. Did the shed roof while I was at it.
Daddystu
Nute
PostPosted: 08:42 - 12 Jan 2024    Post subject: Reply with quote
There was so much salt cacking up the radiator it was pulling moisture out of the air it looked as if the rad was leaking. Washed it all off and just checked this morning in case it was a leak, thankfully not.
A100man
PostPosted: 13:29 - 12 Jan 2024    Post subject: Reply with quote
Jeez - did you do your pants and socks too??!!
DaddyStu
PostPosted: 16:41 - 12 Jan 2024    Post subject: Reply with quote
I did my socks yes. Sealskins - about 10 years old though.
Daddystu
Easy-X
PostPosted: 13:19 - 14 Jan 2024    Post subject: Reply with quote
Looking again at this exhaust box thing on my Husky:
https://i.ebayimg.com/images/g/QxwAAOSwcfFjw2qm/s-l400.jpg
There's a large inlet (>3") and a 2" outlet. Peering inside with a torch it has an odd arrangement of walls (sound dampening fibreglass behind a a mesh) but there's a bit of a gap before this starts so exhaust gasses can flow direct to the outlet. Evidently this chamber's sole purpose is to shape the sound output rather than offer much restriction. Anyhoo, I'll give it a go, see what it sounds like...
Or not Sad While it's nice to get a big box of parts (including this resonance chamber) when you buy a bike that's already modded I don't have any of the fixings. And this thing is heavy, probably more than the mid- & end-link pipes and can. Not something you could just cable tie and duct-tape Smile
Surely I must have some appropriate bolts kicking about...
PostPosted: 20:54 - 15 Jan 2024    Post subject: Reply with quote
Maybe could have posted this in a ‘You are no longer a real man’ thread.
The duke has been loaded into a van to be fixed up.
First time I’ve asked someone to do the work that I couldn’t be arsed to do.
Not much of a defence but decades of working on the bikes outside in a tiny garden has pee’d me off.
I’m going to be a big boy and pay up without a grumble.
Folded arms
Fullers1845
PostPosted: 11:03 - 16 Jan 2024    Post subject: Reply with quote
Folded arms
I'm lucky enough to have a small garage for the bike stuff but nowadays never do anything other than basic servicing on cars.
I resent paying the money, but not as much as grovelling around on damp concrete trying to unseize rusty bolts, or contorting my limbs in an over-stuffed engine bay.
Honda CB125F, Kawasaki ZX6R J1, 1978 Kawasaki KZ650, 1922 Sheffield-Henderson Blackburne grasstrack/sprint
Easy-X
PostPosted: 18:06 - 16 Jan 2024    Post subject: Reply with quote
Looking at scooter today. Splutters but doesn't want to start Sad
Plenty of fuel coming through so doesn't look like a problem with the vacuum petcock. It has a CV carb with one of those accelerator plungers and if you give that a fiddle it will start up for a bit. I'm guessing the carb's gunked up so weighing up whether to strip and clean, check the slide membrane, etc. or just lob in one of those knock-off carbs the Chinese love to churn out Thinking
Easy-X
PostPosted: 15:42 - 20 Jan 2024    Post subject: Reply with quote
Pulled the carb to check the size/part no. turns out it's a 30mm Keihin CVK. Membrane looks good, bowl as clean as a whistle but gave the carb a clean anyway.
Back to basics: spark plug is wet with fuel and sparking lovely on turn over. Checking the airbox... looks fine but then I tried the ol' "cover the air intake" trick the engine started straight up! Pulled the auto choke and taped over the hole (after reassembling the airbox) again, started straight away. We have a winner Smile
Easy-X
PostPosted: 19:50 - 24 Jan 2024    Post subject: Reply with quote
Plonked in the new choke and wired it up. Bike started straight up! Dies if you give it any throttle Sad After fiddling with the carb for a bit the engine suddenly sprang to life. Fuck knows what we did, probably the slide stuck on something.
Anyhoo, left it an hour or so and had a cup of tea. Bike started again fine from cold. Fingers crossed it's sorted.
Kawasaki Jimbo
PostPosted: 19:45 - 30 Jan 2024    Post subject: Reply with quote
Not fitted yet but I’ve just bought a lithium incendiary device battery for the ‘99 ZX6R. Exide ELTX9. A long-established company so hopefully decent.
The bike has a recent history of consuming batteries if laid up for two or three months, and that’s happened because I have two bikes and more significantly, I’ve gone soft in my old age, not riding much through winter. When I rode daily I could get 5 years from a lead-acid battery but I’ve had to buy several new lead-acid batteries over the past few years. The last one lasted 20 months. It’s either parasitic drain (I know how to diagnose that and I have a decent meter but there’s been no indication) or the battery type (YTX9BS) somehow loses charge naturally. My alarm-equipped ‘03 R1 will keep a battery for yonks so it’s a mystery.
I had worked out that a TTZ12S was a suitable upgrade for the Kawasaki. Same dimensions and polarity, lead-acid, but compared to the stock 8.4 Ah, 135 CCA the TTZ12S was a useful 11.6 Ah and 210 CCA. It still wouldn’t survive a lay-up.
The new lithium battery has identical dimensions, 3Ah and 180 CCA, so supposedly between the two lead acid options in terms of cranking ability, but lithium is supposed to crank for longer and tolerate lay-ups for longer too. I’ll report back. It is phenomally light though. When I picked it up I nearly threw it at the ceiling. It also has a button linked to a charge indicating LED (which is nice), and I already have a charger which will accept lithium.
recman
PostPosted: 19:37 - 31 Jan 2024    Post subject: Reply with quote
On this subject, today I have been mostly solar charging. Wink
Kawasaki Jimbo
PostPosted: 20:18 - 01 Feb 2024    Post subject: Reply with quote
I dabbled with a small solar panel 10 years ago and it, plus the prevailing weather, wasn't enough. I note that Halfords and outdoor shops offer bigger panels these days. However, I’m renting so there’s a limit to how much drilling and wiring I can do, and a big ol’ panel on the garage roof tells the local scrotes there’s something valuable inside.
Easy-X
PostPosted: 15:37 - 18 Feb 2024    Post subject: Reply with quote
Mostly finished the wiring on the old Triumph project (swapped to negative ground.) Just some headlight wiring and calibration of the digital speedo left Smile
Villers
PostPosted: 21:28 - 18 Feb 2024    Post subject: Reply with quote
After an awful week I decided I'd take the SV out for it's first run after fixing the magnet issue. Went against risk and ran it up to temp outside the garage to check for leaks while I sorted tyre pressures. Sadly, a bit of a bad leak. Back on the garage and all stripped down, all my previous work seemed fine, the clutch push rod seal has given up the ghost and needs replaced. So have the area a bit of a clean and made a list of bits for the repair happy days!
Easy-X
PostPosted: 17:26 - 16 Mar 2024    Post subject: Reply with quote
Old Triumph project. Calibrated the speedo. Top tip: don't stick the sensor magnets magnetically to the brake disk, they don't work Rolling Eyes Sticking them with double-sided tape to the stainless steel disk bolts for testing was fine though. Span the front wheel by hand, apparently got it up to 10mph Smile Long term we'll drill a slight recess in the bolts and glue 'em in.
As a bonus, bled the front brake and hydraulic clutch.
Easy-X
PostPosted: 18:26 - 17 Apr 2024    Post subject: Reply with quote
Two wheeled vehicles... I fix 'em apparently. This time it's eldest daughter's other half's electric scooter Puke
According to the manual this one's a "Xiaomi Mi Scooter 2 Pro," completely dead though. The battery seemed okay (holding 40V, charges up) so it'd have to be either the dashboard or the controller. I plumped for a matched pair from Aliexpress as it's such an old model but the upside is that the boards are knock-offs from the later models so effectively the scooter gets an upgrade.
Bluetooth pairs to app, allows switching from kph to mph, Celsius to Fahrenheit, changing the speed modes, enabling cruise control (WTF?) and a digital lock. Readouts of the motor power drain, battery capacity and health estimate, regen braking strength... very fancy Smile
There seems to be an whole eco-system supporting eScooters I was unaware of. As long as the base is solid everything else on the scooter can be replaced or upgraded. Fairly cheaply too, given their origin. Almost a shame their illegal Wink
UncleFester
PostPosted: 20:29 - 11 May 2024    Post subject: Reply with quote
MOT'd it. Ridden it. Taxed it. Tomorrows job is bleed the brakes and run new fluid in as that was the other advisory.
Did chuckle when i was sat outside the cafe up the road from the bike place and could hear it going through the emissions part of the test, first thought was "which idiot has a bike that loud" and then realised i'm that idiot. Duly recorded as an MOT advisory "noisy exhaust" Mr. Green
After a little raz home in 2nd and 3rd, it's going to be with me another year.
2017 Z1000SX
Easy-X
PostPosted: 21:09 - 11 May 2024    Post subject: Reply with quote
The old Triumph I did the electrics on... the fucker doesn't want to start. The old fella rings me up today "I thought I'd have another go 'cos I'm bored." If you're bored you can help me rake the grass in my back garden. "Not that bored."
Anyhoo, a couple of ancient Amals running this bike but with no air box or pod filters. First thing I think of is "manual" choke, cover up the intakes and of course the fucker starts on the third kick.
Speaking to the owner (who's a friend of ours mostly living in Thailand) "Not to worry, I have a couple of bell-mouths for those carbs." Not sure how they will be of help Rolling Eyes
UncleFester
PostPosted: 13:00 - 12 May 2024    Post subject: Reply with quote
No idea why bleeding brakes / changing fluid is seen as such a massive ballache. front to back plus master cylinder at lever and a full fluid flush took me 30 minutes - pedal and lever feel plus brake modulation is markedly Improved.
Rear brake feels like its doing something for once. Think I'll do this annually.
2017 Z1000SX
to v or not to v
PostPosted: 17:57 - 12 May 2024    Post subject: Reply with quote
get a vacuum pump. perfect bleeding and takes about 2 minutes.
https://www.ebay.co.uk/itm/391718817400
Moto Guzzi V7.
The last post was made 1 year, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Page 47 of 59
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 137.69 Kb
