Ignition-ZX6R timing pickup coil resistance lower than spec
Fullers1845
PostPosted: 14:34 - 03 Jan 2024    Post subject: Ignition-ZX6R timing pickup coil resistance lower than spec Reply with quote
I have an ongoing issue with hesitation in low/mid range when accelerating that feels like either a fueling issue or a vacuum leak.
I pulled the carbs at the weekend for a clean as well as the rubber carb inlet boots, which had flattened o-rings completely flush to the top of the o-ring groove where they clamp to the inlet manifold.
But I also had a check of the stick coils primary and secondary resistances which were spot on, however for the timing pickup coil the manual states 552 to 562 Ohms, I am getting 526 which is a little low, could this be causing me issues?
Honda CB125F, Kawasaki ZX6R J1, 1978 Kawasaki KZ650, 1922 Sheffield-Henderson Blackburne grasstrack/sprint
Nobby the Bastard
Harley Gaydar
PostPosted: 14:50 - 03 Jan 2024    Post subject: Reply with quote
Coils tend to either work or not work. If it were defective it just wouldn't work.
Triumph Sprint ST 1050
WD Forte
PostPosted: 16:59 - 03 Jan 2024    Post subject: Reply with quote
Pick up coils/pulsers usually have some lattitude in resistance in my experience
as all they have to do in use is provide a pulse of sufficient voltage above a
certain threshold to trigger the sparks.
You'd really need to use a scope to observe it under varying conditions
to see if it's up to the job but some meter tests can give indications
I'll assume you made the resistance reading when cold?
do it again when hot to see if there's any significant difference as
some pulsers have been known to work OK when cold then break down as they heat up
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 17:27 - 03 Jan 2024    Post subject: Reply with quote
I can't see the pickup coil being involved with a hesitation.
Robby
Dirty Old Man
PostPosted: 20:28 - 03 Jan 2024    Post subject: Reply with quote
You found one potential problem in the fuelling already. I would look for more there. If it's at the point where one set of O-rings are either cracked, rotten, broken or flat, then various other ones probably will be too.
Fullers1845
PostPosted: 12:53 - 04 Jan 2024    Post subject: Reply with quote
Cheers all, yes one benefit of this is I'm gradually working through bits that probably needed looking at anyway!
Raffles
PostPosted: 18:52 - 04 Jan 2024    Post subject: Reply with quote
526 isn't low.
The last post was made 2 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 51.02 Kb
