Yamaha ybr 125 2016 wont start
HarryC01
PostPosted: 17:20 - 20 Jan 2024    Post subject: Yamaha ybr 125 2016 wont start Reply with quote
been having a nightmare with this bike not even had it for 2 weeks and it has broken down on me and wont start back up. Had a recovery service come out and say my ignition coil isnt sparking as you can touch it as its trying to turn on and only shocks you once so i think that wire is faulty. My problem is i cant find the spark plug wire/ignition coil? not too sure what the correct name is as i have only just got my first bike and am very new to all of this would be much appreciated if anybody can help me. The lights flash on the dash when trying to turn the bike on and it just chugs away had to connect battery charger to it as it drains my battery fast trying to start it. Any ignition coil i find is not for the 2016 ybr only 2010 and older models but it looks the same connection as the one on my bike just not sure if that will work.
MCN
PostPosted: 17:44 - 20 Jan 2024    Post subject: Reply with quote
If the AA checked and said the coil is fecked, buy and fit a new coil.
Or used from ebay £20-ish.
But you probably need a battery too by what you describe.
And if the battery is fubar, it won't produce the voltage needed to make a big blue spark at the plug.
Coils rely on enough power in to provide enough power out.
Google Internal Combustion engine ignition system.
It is not rocket science.
Rocket science is a Tesla thing now.
PS what sort of 'mechanic' bases his diagnosis on touching an ignition coil?
Was it AA (vehicle rescue and recovery) or Alcoholics Anonymous?
Don't touch live ignition systems with body parts.
It doesn't take too much to interrupt pacemaker electric. Or it's advised not to fuckaboot and findoot.
Easiest and 'safest' it to use an HT current tester. It uses a neon bulb to show the 'power' of the spark current in the sparkplug lead.
Or ghetto, is remove the plug and hold it onto the engine metal as the engine is turned over. Watch for a big fat spark at the plug gap. (Having a spare plug to test helps too.)
HarryC01
PostPosted: 17:54 - 20 Jan 2024    Post subject: Reply with quote
Which coil tho is my problem as i cant find any fitting the 2016 model
HarryC01
PostPosted: 17:58 - 20 Jan 2024    Post subject: Reply with quote
this is the one i have been looking at as it looks identical to the one on my bike https://www.ebay.co.uk/itm/163581674416?fits=UKM_CCM%3A125%7CUKM_Submodel%3A--%7CYear%3A2016%7CUKM_StreetName%3A--%7CUKM_Make%3AYamaha%7CUKM_Model%3AYBR&_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D259360%26meid%3D95fa9dbee6f247dbb029b99c45c5d395%26pid%3D101195%26rk%3D1%26rkt%3D12%26sd%3D174206217685%26itm%3D163581674416%26pmt%3D1%26noa%3D0%26pg%3D4429486%26algv%3DSimplAMLv11WebTrimmedV3MskuWithLambda85KnnRecallV1V2V4ItemNrtInQueryAndCassiniVisualRankerAndBertRecallWithVMEV3CPCAutoWithQueryItemPopRecall&_trksid=p4429486.c101195.m1851&amdata=cksum%3A16358167441695fa9dbee6f247dbb029b99c45c5d395%7Cenc%3AAQAIAAABgNdtxAoBpaK9lxbZYqLKr57VyakGXKqPqDR%252B6zIMONpEUSQEGZ9t73llm8hHkiY0YgFnB0h8MjSJfcxjR%252Fc%252Bv5%252BWjXGgOrY93jdAwi063LExQrejqagsq3LQWOJ8eZ03t%252FHsuFeKXgtFlBhL65eDwzk22rnIIHWzWkYBJnssaXQKnpmWkCtVl34Ir%252FXCecY5m4MkdwlHEuPQbt6Z6GtfwPyvglY3l65g%252F8GEmW0tZ4piDiMYvD4DeOv6jHJgboOzxpvD1mGGGXBhrmvbea6gQWmMkzqJWL%252Fy9vcWH8WYvuILt%252FvV%252Fplh2ypVdalvjLR3T9Gxhy1KSWfz%252F4v7uawX8%252FsKCgjVQopFygssgxQnHbjWKZT570fGK5JzMzLY52nT0aa0ZGTKBfvMIt%252Bwfq6fpWD%252FNK7Df%252F54AeLc0k27oetZQdfrFhVJcv396JBpvBBgIvfbPTROifpkgdVSzS31fRym3H%252Bu5YamOy8tHzXmBZIYb6p0FoG%252FTBmNI8ICFbMVgg%253D%253D%7Campid%3APL_CLK%7Cclp%3A4429486
MCN
PostPosted: 18:03 - 20 Jan 2024    Post subject: Reply with quote
Get your head into the books before lashing the cash.
It's only a big issue if you don't fully understand the theory of ignition.
Coils sometimes are not good or bad.
They suffer from weirdness too.
You 'should' get some indication of failure by measuring the insulation between the input terminal and the body/earth.
They should have substantial resistance. The OEM books should provide the specific values.
Do you own a multimeter? Do you know how to use a multimeter?
Sort of necessary for ignition diagnostics.
WD Forte
PostPosted: 18:39 - 20 Jan 2024    Post subject: Reply with quote
That's the wrong coil, that's for the early YBR's with CDI ignition
EFI YBR's use a 2 blade coil.
Fowlers have the correct coil in stock
https://www.fowlersparts.co.uk/parts/5452385/ybr125ed-2014-51d3-europe-vivid-red-cocktail-7/electrical-2
IF you really need one that is !!
As per MCM, I'd do some more testing before spending
bikers smell of wee
WD Forte
PostPosted: 18:43 - 20 Jan 2024    Post subject: Reply with quote
If the YBR eml gives you 33 (3 long 3 short flashes) that's it saying
it doesn't like the coil
pay attention and note the flashes
19 ( one long, nine short) is another common fault on YBRs
turn on the ignition watch the wee yellow lighty and count
it will keep flashing out the same codes over and over until you turn the
ignition off
bikers smell of wee
HarryC01
PostPosted: 19:01 - 20 Jan 2024    Post subject: Reply with quote
ignition off
yeah i just went out and tested i got 1 long and 9 quick flashes on the little lighty bit. also i spoke to somebody and they said this would fit and have ordered it should i cancel it? https://www.ebay.co.uk/itm/272229906138
WD Forte
PostPosted: 19:05 - 20 Jan 2024    Post subject: Reply with quote
NO!!
that's single blade CDI type coil
useless on an EFI YBR
did you not read wot i rote?
I dont reckon you need a coil anyway
code 19 is not the ecu saying its a coil fault, its related to the side stand switch loopback
and there's an easy work around for this
bikers smell of wee
HarryC01
PostPosted: 19:11 - 20 Jan 2024    Post subject: Reply with quote
WD Forte wrote:
NO!!
i had already purchased it my bad. im not sure why the recovery guy has told me i need a new coil in the first place. but is this something i can do myself as i have little to no knowledge of bikes.
WD Forte
PostPosted: 19:29 - 20 Jan 2024    Post subject: Reply with quote
It's a pretty easy cheap and quick job to by pass the sidestand switch
in fact it will cost almost nothing to get you running again if you by pass it but more if you need and fit a new switch.
I have never owned a YBR but done loads of work on one for a local guy who sadly seem incapable of learning to do stuff for himself
As your a newbie some advice
TEST dont guess!
Buy a manual, read it and get to know your bike.
people who do this tend to have more reliable, cheaper to run bikes
Buy a multi meter, they're cheap and can save you plenty of time and money
Ask on this forum first!
There's a shit ton of pisstaking goes on, but most of the folk here
are pretty smart and experienced and I've never known any of the regulars to deliberately give bad technical advice.
so pay attention and don't flounce
bikers smell of wee
WD Forte
PostPosted: 19:40 - 20 Jan 2024    Post subject: Reply with quote
Have to go out but in short:
the quick fix is to short the black and black/white wires at the igntion switch together to by pass the faulty side stand switch
Be careful not ride off with the side stand down and look into
getting a new switch or fixing the wiring fault
bikers smell of wee
HarryC01
PostPosted: 19:56 - 20 Jan 2024    Post subject: Reply with quote
will definitely try to bypass the switch first as it seems the easiest way but its also not sparking at the spark plug cap is that because of this error too not just faulty spark plug? i will wait on ur reply you have been more help than RAC
Nobby the Bastard
Harley Gaydar
PostPosted: 20:04 - 20 Jan 2024    Post subject: Reply with quote
It's not sparking because the switch is telling the ecu not to spark. Thats why you need to bypass.the switch.
Triumph Sprint ST 1050
HarryC01
PostPosted: 20:15 - 20 Jan 2024    Post subject: Reply with quote
do you know where i can find a tutorial or instructions to do this?
Nobby the Bastard
Harley Gaydar
PostPosted: 20:30 - 20 Jan 2024    Post subject: Reply with quote
Are you ill-informed or are you just incredibly stupid?
HarryC01
PostPosted: 20:32 - 20 Jan 2024    Post subject: Reply with quote
i have 0 knowledge of bikes or electrics as i said this is my first bike not even had it for 2 weeks i seriously have no clue
Nobby the Bastard
Harley Gaydar
PostPosted: 20:38 - 20 Jan 2024    Post subject: Reply with quote
It's electrics. Did you do any science at school?
WD Forte
PostPosted: 21:17 - 20 Jan 2024    Post subject: Reply with quote
OMG
Only been here 10 minutes and Nobby's got right into him
https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Fmedia.giphy.com%2Fmedia%2F8RMthc4z4iZQA%2Fgiphy.gif&f=1&nofb=1&ipt=a6cd05a0a61265de3888f2e32fcb83b39b9462b9156b1757485d83090e8d8aa8&ipo=images
Now, the question is, does he flounce or not?
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 21:30 - 20 Jan 2024    Post subject: Reply with quote
In my defence I've had a torrid couple of weeks and am really not in the mood to be gentle.
HarryC01
PostPosted: 00:06 - 21 Jan 2024    Post subject: Reply with quote
WD Forte wrote:
Still have no clue how to fix this think I might just get RAC to recover the bike to a garage and get them to look at it
virus
PostPosted: 00:27 - 21 Jan 2024    Post subject: Reply with quote
WD has pretty much told you how to fix it based on the information you've given.
from here you have 2 choices;
1) read and learn (stop to google terms you dont understand etc) then maybe you can fix it yourself for free and also learn more about the machine your riding.
2) just pay someone to fix it, not only this time, but every time its got any slight problem.
one of those choices will make you poor, the other choice will make you self reliant depending on how far down that path you go.
own: 81 xs1100g...
WD Forte
PostPosted: 00:35 - 21 Jan 2024    Post subject: Reply with quote
Up to you
Do that and you'll be none the wiser, out of pocket and prey to any
half assed mechanic in the future.
Get it brought home and do it yourself and you'll learn
I'm told by my YBR owner who also has 2 delivery scoots
bike shops around here charge from 40 to 100 quid an hour
for labour.
There is a cheaper place he goes to but they're fucking useless
so he often has to bring it to me to put right after they 'fixed it'
It's an easy job, I could do it with a screwdriver, a pair of cutters or pliers and some electrical terminal block in less than half an hour.
bikers smell of wee
WD Forte
PostPosted: 00:41 - 21 Jan 2024    Post subject: Reply with quote
Just had butchers at the YBR manual
Try this
Select neutral
turn on the ignition and pull the clutch lever in and hold it in as
you press the starter
If it starts but cuts out as you release the lever the side stand switch is
the fault
all this does is confirm the fault not fix it but at least it does tell you the
black/white wire fix will get it running so
all you need to do is cut it, strap it to ground and off you go
bikers smell of wee
HarryC01
PostPosted: 00:47 - 21 Jan 2024    Post subject: Reply with quote
Try this
Select neutral
the fault
Will give this a shot in the morning thank you for your help everybody I know I’m pretty clueless with this so it’s good to see a couple of you have got patience
The last post was made 2 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 134.11 Kb
