Negative ground digital speedo on Positive ground loom
Easy-X
PostPosted: 18:42 - 02 Feb 2024    Post subject: Negative ground digital speedo on Positive ground loom Reply with quote
It's Friday. Brain has given up. Insufficient beer supplied Neutral
Working on an early '70s Triumph with a positive ground loom and attempting to add a Koso digital speedo (custom wheel hubs, no mechanical speedo drives present.)
The instructions call for permanent +12V, switched +12V and ground i.e. very conventional. With this Triumph the frame is +12V from the battery with permanent power (via the loom) going to the 0V of the battery and so switched power is also 0V.
So either some sort of circuit rearrangement required or - the extreme option - changing to a negative ground loom. Note the Koso speedo is in an isolated case so "metal touching metal" not an issue and the Boyer Bransden ignition is happy with either negative or positive ground systems.
PostPosted: 20:12 - 02 Feb 2024    Post subject: Reply with quote
So permanant +12v to the frame. A SPNO relay controlling the switched +12v, earth wired to a permanant "live" wire on the bike.
Relay is just a switch, it'll switch anything. I have relay controlled AC lighting on my trials bike (DC from the switch to trigger the relay).
EDIT: Re-upped diagram due to brain fart.
https://www.bikechatforums.com/download.php?id=106645
WD Forte
PostPosted: 22:01 - 02 Feb 2024    Post subject: Reply with quote
I'd convert it to neg ground
It's pretty straightforward with less chance of confusion.
Having a conventional system would also give you the
ability to easily add or modify gadgets and stuff later if wanted/needed.
fuck the 'classic innit mate' shite, i wouldn't cling to pos ground
any more then I'd stick with points ignition, AC and incandescent blubs
bikers smell of wee
PostPosted: 22:52 - 02 Feb 2024    Post subject: Reply with quote
He could run gadgets using his switched +ve relay above.
Good quality LED bulbs aren't polarity sensitive any more.
There may be reasons for using AC lighting. In my case 1) It works really well and 2) The DC only runs the ignition (and a relay) on that particular bike meaning I get away with an outrageously tiny battery
Easy-X
PostPosted: 22:58 - 02 Feb 2024    Post subject: Reply with quote
Thinking on it I was going for a semi-concealed, minimalist LED tail light. As it's two-stage I'd face a similar problem so that's 2 relays now Sad
If I go with negative ground I could either swap the red & brown over, maybe add a bit of black heatshrink the "new" ground, or burn money getting a later model loom.
I'll give the bike a long hard stare tomorrow.
PostPosted: 00:02 - 03 Feb 2024    Post subject: Reply with quote
You get positive earth LED stop and tail lights. Unless it's AC/DC?
For example:
https://www.classiccarleds.co.uk/products/2-x-bay15d-red-stop-tail-led-4014-30-smd-brake-rear-light-glb380-p21-5w-classic-car-negative-or-positive-earth
WD Forte
PostPosted: 00:36 - 03 Feb 2024    Post subject: Reply with quote
I converted the moby from AC shite lights and points ignition
to run with no battery and leds that actually gave out light nae bother
I assume we're talking '71 T120 or similar?
well I just browsed a couple of contemporay diagrams and
it's not much more complicated and in some ways even easier
Yes there are work arounds/get you home methods
but they're short term IMO
I reckon having a mixture of grounds is a bad practise when you can have a regular conformal system ready to use easily available,
off the shelf stuff that can easily be swapped out, modded and upgraded
It also sticks to the K.I.S.S. rule.
I rode these old bikes when they were commonplace, they had crap electrics even then so I'd have no hesitation in upgrading them
if I was forced to own one.
but it's your shitty old bike, do what you want
bikers smell of wee
Easy-X
PostPosted: 11:37 - 03 Feb 2024    Post subject: Reply with quote
...but it's your shitty old bike, do what you want
Early 70's is about the most we can assume. FYI it's a project from a friend of a friend.
Easy-X
PostPosted: 12:16 - 04 Feb 2024    Post subject: Reply with quote
For now I'm just swapping the battery terminals over on the loom. Red = 0V, Blue/Brown = +12V, White = +12V switched (using a Lucas loom.)
I disconnected everything and wired up just the brake light and that worked out fine. Now I'm working through the wiring diagram and thinking through the implications. Mainly just redoing the ignition system.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:41 - 04 Feb 2024    Post subject: Reply with quote
What sort of charging system does it have? It would be positive ground and so some sort of swapping of wires may need to be done there too.
Triumph Sprint ST 1050
Easy-X
PostPosted: 14:26 - 04 Feb 2024    Post subject: Reply with quote
Thankfully not a problem. The ignition system is the aftermarket Boyer Bransden Mk4 and it's paired with their "power box" (the stator's already been swapped for a single phase sort that the power box needs.) And B.B. have wiring diagrams for both positive and negative ground systems.
Easy-X
PostPosted: 18:34 - 10 Feb 2024    Post subject: Reply with quote
Back end re-done as negative ground, just need some cable ties:
https://i.imgur.com/EAS0LaP.jpeg
Kicked it over and getting spark.
Following the minimalist aesthetic, stripped the front loom to the essentials:
https://i.imgur.com/bS5BZFB.jpeg
To do: wire up a hi/lo beam switch, horn button, speedo and ignition.
The last post was made 2 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 76.29 Kb
