A maths challenge for you...
MaybeGuy
PostPosted: 04:23 - 05 Feb 2024    Post subject: A maths challenge for you... Reply with quote
I'm designing a flip up window of sorts, but I'm being "extra" with it...
It's been too long since I was at uni, and I can't get my head around this without hours of trial and error.
Basically I want the two panels to be near parallel when the window is closed (for sealing purposes y'see). With about a 10-15mm gap with the seal fully squished.
https://i.ibb.co/BZyPL68/Screenshot-2024-02-05-141826.png
When it's open, I want it to have usable access, let's say an upward angle of approximately 45 degrees, but the lower edge roughly in line with the top edge of the window bezel.
https://i.ibb.co/zJfLc52/Screenshot-2024-02-05-141848.png
And finally, the mechanism.
https://i.ibb.co/ZfPtS1W/Screenshot-2024-02-05-141913.png
Call it an arbitrary length of 100, so the lengths can be scaleable and ratios of one another, but basically the arm lengths and mounting hole distances are the critical bits.
I'll add a limit to the rams range of motion of ~125mm (although if you can get it within 75mm I don't have to buy more gas struts).
Go forth, and math!
PostPosted: 08:36 - 05 Feb 2024    Post subject: Reply with quote
I'd just get some off the shelf fire-escape PVC window hinges which do almost exactly that then modify them to add the gas strut.
https://www.handlesandhinges.co.uk/fire-escape-easy-clean-window-hinges/
MaybeGuy
PostPosted: 12:30 - 05 Feb 2024    Post subject: Reply with quote
But then it wouldn't do the funky inversion upside down thingy, yo!
Anyway, I think I got it. It took some faffing and curly bits.
https://i.ibb.co/wM38Y9n/Screenshot-2024-02-05-223000.png
https://i.ibb.co/GT8hN1L/Screenshot-2024-02-05-223413.png
https://i.ibb.co/fHdFRm0/Screenshot-2024-02-05-223346.png
The last post was made 2 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 38.42 Kb
