Peugeot Kisbee 50cc woes.
WmY
PostPosted: 17:58 - 21 May 2018    Post subject: Peugeot Kisbee 50cc woes. Reply with quote
Well, there doesn't seem to be an "Introduce yourself" subforum; please correct me if I'm wrong and I'll write something there.
So my son, 16, wanted a moped/scooter (licence class AM). So, we thought, oh, no, no, not one of those Chinese things... it would be better to get a European one. HOLLOW LAUGH. The Peugeot Kisbee bought second-hand, if it isn't actually made in China, has a Chinese 139QMB-E engine. Bother.
So, at 9,500-odd Km, about 400Km after buying it, it started to rattle....
Stripping the thing shows that the alternator-side main bearing's bearing cage has collapsed. The big end seems OK. So, replacement main bearings are needed.
The drive side bearing is a standard & popular 6304 deep groove ball bearing, unshielded, standard clearance.
The alternator side bearing is similar, but a funny one - it's got "SC03A39CS" stamped on the outer race, and measures 17-42-13 (mm).
Any ideas on where to get good quality replacement bearings, please?
Octapode
PostPosted: 20:10 - 21 May 2018    Post subject: Reply with quote
This would seem to match your specs: https://www.123bearing.co.uk/bearing-SC03A39CS20-NTN.php
This kit looks like it matches your engine: https://www.pedparts.co.uk/product/3192/bearing-and-seal-kit--chinese-gy6-50cc-4t
Both look like they're the same NTN bearing, so either should be decent quality.
Hope that helps.
WmY
PostPosted: 20:21 - 21 May 2018    Post subject: Reply with quote
Hope that helps.
Wow, I found the "123bearing" bearing just before I read this! They've also got a 6302-17P53-NTN which seems to be the same. Any idea what the difference might be (unsure what "CS20" at the end of the first link is)?
Thanks very much for the "pedparts" link. It's a good price considering it comes with seals and both bearings, but they're out of stock. I e-mailed them to ask when they're likely to get more in.
It's odd - they muct churn these scooters out in huge numbers. One would think bearings would be easier to come by (and not made of cheese...).
WmY
PostPosted: 12:19 - 22 May 2018    Post subject: Reply with quote
OK, for completeness:
Pedparts say new stock will take 2/3 weeks to arrive. Their kit ( Bearing & Seal Kit - Chinese GY6 50cc 4T #P3192 £24.95 ) is a good price including both bearings and seals.
In view of this I ordered from 123bearing. The cost is rather higher though (about £32 without seals BUT including VAT and 2day delivery (from France) ).
Notes:
Bearing (alternator side):
The Pedparts 6204 bearing has C4 clearance[1]. This is "slightly loose" apparently to cater for big bore conversion kits.
123bearing recommended a C3 bearing for this application (above 70 degrees C, high speed). This clearance is not so "loose" as C4. I ordered this one.
Bearing (drive side):
123bearing was again extremely helpful. They carry two equivalent bearings: SC03A39CS20 and 6302-17P53, both made by NTN. I include these numbers since they are not easy to find "from scratch".
[1] For more information on bearing clearances see: https://www.skf.com/uk/products/bearings-units-housings/ball-bearings/deep-groove-ball-bearings/designation-system/index.html?WT.oss=c2%20c3%20c4&WT.z_oss_boost=0&tabname=All&WT.z_oss_rank=1 and elsewhere.
WmY
PostPosted: 00:09 - 28 May 2018    Post subject: Reply with quote
My goodness! The detritus in the engine; flakes of metal from the chatter on the inner race, alternator side, plus knock-ons; wash them out with paraffin, blow through the galleries and surfaces, even the gear-type oil pump is full of it. Still, after a spell cluttering up the workshop, it'll be cleaner than it was at manufacturing time. Haven't seen such stuff in an intact engine since the old Matchless developed octagonal roller bearings in the big end.
There is a gap of 5 years, 267 days between these two posts...
Gcardale
PostPosted: 17:26 - 18 Feb 2024    Post subject: Kisbee engine main bearing Reply with quote
Hi, I am rather afraid my sons has had the same issue, there is a loud knocking side from the left-hand side of the engine block. How difficult or straightforward is to split the engine , and will the engine need to be fully split to fit the bearing ?
George
MCN
PostPosted: 18:03 - 18 Feb 2024    Post subject: Re: Kisbee engine main bearing Reply with quote
5 year old thread.
Maybe a response if you post a new thread.
Spammers And AI post in Old threads.
The last post was made 2 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 55.02 Kb
