| Nobby the Bastard |
 Posted: 12:09 - 10 Mar 2024 Post subject: Battery drain issue |
So, bought a battery because the old one died, stranding me in Bristol a few weeks ago.
On arrival, it couldn't start the bike, it was saying 12.3V. Charged it up and the bike started with no issues.
Went to use the bike a couple of days later and it wouldn't start again, battery only showing 12.5V. I persevered but it consistantly would not work, after being left overnight, but if charged that day was fine.
Supplier sent another, that was dead on arrival at 12.1V.
They both went back and a new one sent to me (different make) which was on 12.6V on arrival, was unable to start the bike and after 20 seconds of cranking was at 12.3V.
Started the bike once charged but after being left overnight can't start the bike, same before and after voltages same length of cranking.
Draw by the bike for clock etc is 20mA but the battery wasn't even connected when left overnight.
I'm a little loathe to think its another duff battery but I can't find anything wrong with the bike. It starts on the button with a freshly charged battery.
Any ideas? ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
| Easy-X |
 Easy-X Super Spammer
 Posted: 13:42 - 10 Mar 2024 Post subject: |
Two properties of a battery one would be interested in: can it supply ~12V over a long period at a low current drain (normal running) and can it supply a shed-load of power for a few seconds (cranking current.)
So far, so obvious. I would suggest either the batteries are not chucking out the power they should or for some reason the bike is asking for more power than it should. That a completely topped-off battery can start the bike but an even slightly discharged battery cannot points to the bike demanding much more power than it should to crank over, I would say.
Before I changed the (probably the 2016 OEM) battery on my XSR I'd occasionally have trouble starting it, e.g. left for >1 week. In the borderline cases where you could hear it struggling but it did manage to start the battery voltage was between 11~12V which is much worse than what you're encountering.
I'd be thinking about the starter motor, starter solenoid and starter switch. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Nobby the Bastard |
| Nobby the Bastard |
| Fizzer Thou |
| Nobby the Bastard |
| WD Forte |
 WD Forte World Chat Champion
| Fizzer Thou |
| P.addy |
 P.addy Red Rocket
| Nobby the Bastard |
| Kawasaki Jimbo |
| Nobby the Bastard |
| Nobby the Bastard |
| Nobby the Bastard |
| MCN |
 MCN Super Spammer
| Robby |
 Robby Dirty Old Man
| Nobby the Bastard |
| jeffyjeff |
 jeffyjeff World Chat Champion
| Nobby the Bastard |
| A100man |
 A100man World Chat Champion
 Posted: 12:44 - 11 Mar 2024 Post subject: |
| Fizzer Thou wrote: | So it is a lead/acid type then....
They come from the factory 'dry charged' but still need to have at least 20 hours charge with a constant rate of about 1 amp for motorbike use.
Car battery chargers are useable but charge at far too high a rate and can buckle the plates.Some chargers have the option of car or motorbike use but the one that I have I fit a one ohm 5 watt wire wound reisitor in series to reduce the current flow.This then reduces as the internal resistance of the battery increases as it charges.
This is only for first charge right? Otherwise every battery would get 'buckled plates' in use since most alternators output more than any carcharger. Eg my XJ can output upto 17A and my car charger only 6A maximum. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Fizzer Thou |
| A100man |
 Posted: 16:39 - 11 Mar 2024 Post subject: |
Years ago I did have a problem on a car with a voltage reulator that was allowing the output of 17vdc to cause the battery to overcharge and pop off the plugs,spraying acid all over the area under the bonnet.The battery itself suffered as a result. |
Yep that'll do it, also excessive sulphating, often due to to undercharging I read . I still doubt though that a normal working battery charger operating at 14.5V will damage a battery even if the current rate exceeds the 1A guide. In service they can pull more than that for sure. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Nobby the Bastard |
The last post was made 2 years, 251 days ago. Instead of replying here, would creating a new thread be more useful? |
