Battery drain issue
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
Nobby the Bastard
Harley Gaydar
PostPosted: 14:20 - 12 Mar 2024    Post subject: Reply with quote
Update:
Power was dropping when connected to the bike but doesn't when not connected so I looked for parasitic draws again.
In the past someone swapped the reg for one that has a wire directly to the battery and this is unfused so any drain on that wouldn't appear if using the fuse connector to test. The drain is 50ma on that wire so my reg is dying.
This is also likely to be responsible for the majority of the 20ma draw I found on the fuse box especially as Mr Haynes (rest in peace) says the draw should not exceed 1ma.
This combined with wemotos lack of charging ability has caused me to lose my sanity.
Triumph Sprint ST 1050
WD Forte
PostPosted: 15:21 - 12 Mar 2024    Post subject: Reply with quote
If yours is sorted now then good.
This reminds me of old Hondas which often used a Shindengen RR which had a black external sense wire patched into the
switched power/ignition on side of the loom.
This was probably fine originally and intended to compensate for voltage drop in use with say, lights on.
Over time (years) poor connections/weather/abuse/neglect could cause the connection to 'float' and the batteries could get over charged.
As an experiment I started patching my sense wires directly to the battery pos and always got a steady 14.2V when running with no detectable drain issues.
Parasitic drain was mentioned as a possible side effect if this but in my case it wasn't an issue
It's almost impossible to say why this method worked for years for me
without comparing the circuitry of the devices involved.
bikers smell of wee
MCN
PostPosted: 15:48 - 12 Mar 2024    Post subject: Reply with quote
Yuasa and Mottobat are what I've been using for donkeys.
I was using Yuasa but a couple of them died early even when connected to a ctek charger.
The mototbatt in my k1300 has been in there for about four years now.
I suspect its due to be replaced as its sounding a bit dour to start. It usually birls the hoowur over like there's nothing to it.
I just price checked a battery.
Fucketyfuck!
I wish I never joined this thread now.
"MotoBatt is an AGM battery, a type of Sealed Lead Acid (SLA) battery.
This is a high torque battery. The cold cranking amps exceeds that of original equipment.
Each Quadflex Battery has 4 terminals (2+ and 2-) and, when necessary, includes spacers for flexibility and fitting.
No electrolyte or harsh acids to deal with, MotoBatt Batteries require no maintenance. MotoBatt batteries do not even require charging before being put on the bike, they are ready to install directly out of the box."
Nobby the Bastard
Harley Gaydar
PostPosted: 13:47 - 15 Mar 2024    Post subject: Reply with quote
So, reg replaced because it was clearly leaking when it wasn't supposed to but we have a new problem.
I think we are back to starter motor judging by the bad noise.
It makes the same noise if you bypass the solenoid so it's not that.
https://www.youtube.com/watch?v=-sxY5IAXteg
Easy-X
PostPosted: 14:29 - 15 Mar 2024    Post subject: Reply with quote
"That didn't sound very healthy" Laughing
My guess is the motor's okay but the sprag's knackered.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:31 - 15 Mar 2024    Post subject: Reply with quote
Yeah, thats Mr Fisty's opinion as well, known issue with weak batteries.
£189 plus another battery...
Nobby the Bastard
Harley Gaydar
PostPosted: 16:02 - 15 Mar 2024    Post subject: Reply with quote
Yes, the no.2 has a bit of a way with words.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:57 - 15 Mar 2024    Post subject: Reply with quote
Mary, mother of god....
A new sprag clutch is £270...
Nobby the Bastard
Harley Gaydar
PostPosted: 11:31 - 02 Aug 2024    Post subject: Reply with quote
Holy necro!
I finally had s look at the starter clutch on this and it turns out it's not knackered.
The starter motor, however, has stripped gears. They only cost £80...
Nobby the Bastard
Harley Gaydar
PostPosted: 12:54 - 02 Aug 2024    Post subject: Reply with quote
https://www.bikechatforums.com/files/untitled_148.jpg
Robby
Dirty Old Man
PostPosted: 14:24 - 02 Aug 2024    Post subject: Reply with quote
I know the diagnosis.
It's fucked.
Nobby the Bastard
Harley Gaydar
PostPosted: 11:59 - 09 Aug 2024    Post subject: Reply with quote
The strumpet lives!
Mtucker This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 1 year, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.98 - MySQL Queries: 13 - Page Size: 76.51 Kb
