Recommend a VOIP provider?
PostPosted: 20:31 - 03 Apr 2024    Post subject: Recommend a VOIP provider? Reply with quote
In anticipation of the landline system being shitcanned and having sketchy mobile signal at my house. I use a roaming SIM, you get vodaphone downstairs and EE upstairs but if you made a call then go up or downstairs, you lose the signal. At best it's patchy and unreliable, even more so since they turned off 3G because I don't get 4G unless you stand with your head in the windowsill in the upstairs bedroom.
As such, I'd much prefer to use the house phone and would like to retain my "landline" number.
The logical thing seems to be to get a VOIP adapter for my existing DECT phones and a VOIP callplan.
Ideally have a callplan that includes uk landline and mobile calls. Either an unlimited one or at least 300 minutes monthly.
Ideally be able to port across my existing landline number.
No experience of VOIP providers. Anyone got experience/recommendations?
Islander
PostPosted: 23:43 - 03 Apr 2024    Post subject: Reply with quote
I've been using MyPhones Altos VoIP for years. I originally got it as part of a satellite internet system when I binned BT through the satellite reseller. I've been happy with it. I'm not up to speed with domestic SIP/VoIP suppliers so can't really help you with that part.
Porting your BT number is a doddle and the transfer is seamless. You'll have to dial the full STD number when you dial out though, even for local numbers.
Your DECT system can be used on a VoIP supplier's system. They should be able to provide you with a device called an ATA (Analogue Terminal Adaptor). It plugs into your broadband, and your phone system plugs into it. The beauty of having an ATA is that you can take it anywhere and plug it into a broadband connection and you'll have your home number available. VoIP is very flexible.
I'm not sure what call deals are available but you should be able to find comparison deals online. VoIP calls are a lot cheaper than BT.
Easy-X
PostPosted: 01:21 - 04 Apr 2024    Post subject: Reply with quote
If you want dirt cheap then I can vouch for Andrews & Arnold. Mun's old landline number from Cornwall redirected to her mobile costs me less than £2 a month.
The crucial detail you'll need for any VOIP transfer is who is providing the hardware at present, e.g. for a BT line it'd be OpenReach. In my case Shell Energy deliberately fibbed about this and it cost me a few days and £15 in admin fees for A&A to do the research.
While they're cheap, A&A is a bit fiddly to set up. Sounds like you're probably going to link with a VOIP handset rather than an easy redirect. Regardless of who you go with I'm sure Islander or myself can chip in some technical pointers.
Robby
Dirty Old Man
PostPosted: 18:59 - 04 Apr 2024    Post subject: Reply with quote
Does your phone/mobile provider not offer wifi calling?
It routes your phone calls through your router, so if you have a crap mobile signal but reasonable wifi, you can still make calls.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:28 - 04 Apr 2024    Post subject: Reply with quote
On sky fibre, my phone plugs into the router.
Triumph Sprint ST 1050
doggone
PostPosted: 22:38 - 04 Apr 2024    Post subject: Reply with quote
No mobile signal here, nearly everyone uses mobiles on wifi calling I can't see why you'd pay more for voip.
I have cheap mains adapter extensions out to (farm) yards so can use it over a decent area.
Wifi calls are charged or listed just like network calls/
PostPosted: 22:51 - 04 Apr 2024    Post subject: Reply with quote
I don't and wont have a smartphone.
PostPosted: 22:21 - 05 Apr 2024    Post subject: Reply with quote
I've been trying Google Voice but smartphone init.
I have zero signal here and rely on WiFi calling but my internet is also shit through landline so I have Starlink which works fine, its not perfect but its also not 0.7Mbps upload.
I used to use SIPGate but now its ££
A100man
PostPosted: 10:53 - 08 Apr 2024    Post subject: Reply with quote
I sympathise but I'm not sure this is a fight you can ever win.
Even I have one (albeit a SIM free Alcatel from Argos that cost 70 quid), and so does my 87 year old mother.
I don't and won't ever have 'Facebook' however.
Easy-X
PostPosted: 13:36 - 08 Apr 2024    Post subject: Reply with quote
Facebook on mobile is a whiney little bitch. Didn't get re-installed when I last upgraded my phone. That does mean it's tricky to sell stuff through Marketplace... win win I suppose Smile
kawakid
PostPosted: 21:40 - 11 Apr 2024    Post subject: Reply with quote
I've used sipgate for over 15 years.
I have a cisco sip adapter which let's me use a traditional phone.
I don't pay line rental only call charges.
I've a twin and a 4.
There is a gap of 1 year, 181 days between these two posts...
Zapatchco
PostPosted: 15:31 - 10 Oct 2025    Post subject: Reply with quote
I had the same issue with patchy signal at home and switched to a VOIP setup. Got a DECT adapter and a plan that let me keep my landline number. For calls, I tested a few providers and found telxi solid — clear calls, easy setup, and decent rates for UK calls. They even made porting simple.
Easy-X
PostPosted: 19:36 - 10 Oct 2025    Post subject: Reply with quote
Zapatchco wrote:
I just note down the MPG shown on the trip and how much fuel I put in each time, then compare to get a rough average over time. Works fine for me.
Is this on the way to or from the brothel where you work as a fluffer?
The last post was made 1 year, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 78.49 Kb
