Garage 54 - too much engine oil
Easy-X
PostPosted: 12:40 - 10 Apr 2024    Post subject: Garage 54 - too much engine oil Reply with quote
Clear plastic sump plus a side window into the crank case:
https://www.youtube.com/watch?v=VaTbfvzNbxQ&ab_channel=Garage54
tl;dr a little over max doesn't make much odds but the more you put in the more the oil gets aeriated.
https://www.machinerylubrication.com/Read/690/aerated-oil
PostPosted: 20:06 - 10 Apr 2024    Post subject: Reply with quote
If you overfill an older engine like the one on my enfield, unless you go to the extent of hydrolocking it, it just spits it out of the crankcase breather until it has the correct amount again. I've overfilled it a couple of times when it wet-sumped while parked up and I topped it up thinking it was low. So you land up with about 200ml more than you ought to have as it pumps the crankcase out.
Makes an unholy mess and smokes a bit for a short while but no real mechanical damage.
I know better now and run the engine for a couple of minutes before checking the dipstick.
The last post was made 2 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 32.36 Kb
