2007 FZ1 brake light not working
TravisBickle
PostPosted: 15:24 - 23 Apr 2024    Post subject: 2007 FZ1 brake light not working Reply with quote
Not illuminating with either front lever nor rear pedal.
It's not the bulb.
Any ideas?
2024 BMW M1000XR
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport
RhynoCZ
PostPosted: 18:22 - 23 Apr 2024    Post subject: Reply with quote
Fuses and switches.
Islander
PostPosted: 21:37 - 23 Apr 2024    Post subject: Reply with quote
Or ground connection. Or wiring. Or connectors.
Get your multimeter out and get testing.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:32 - 23 Apr 2024    Post subject: Reply with quote
I'd normally be blaming the earth but you aren't saying the rear light isn't working entirely.
If it is, the loom between the middle of the bbike and the rear light.
Always assuming that you have actually checked that the bulb is working by unpluging the brake light from the subframe and checking that there is actually continuity through it to earth.
Triumph Sprint ST 1050
TravisBickle
PostPosted: 03:14 - 24 Apr 2024    Post subject: Reply with quote
Sorry guys I should have said - I hadn't checked the fuses but I had checked what they all do online before posting this and as none of them specify for brake lights, I assumed the brake lights must be on a shared fuse (maybe with the tail light?), and seeing as everything else seems to be working fine I had assumed that mustn't be the case.
Was on the way out to the footie when I posted and hadn't had time to look into it thoroughly before I went, although I did swap the bulb for a brand new one quickly before I left and still no joy, was hoping for a silver bullet when I got back, alas, good advice where to start looking nonetheless.
Tail light working so I had also assumed ground was out of the equation also.
Turns out both switches had corroded and weren't making a connection, and the rear switch needed adjusting as it wasn't pulling hard enough on the switch spring anyway. Bit of WD40 and some buggering around got the rear one working but still no joy from the front so I've stripped it and roughed up the contact areas, going to leave it to soak overnight and hope for the best. Failing that, new switch.
I appreciate the help. As both weren't working I'd assumed switches were probably fine as chances of BOTH being broken/corroded at the same time slim?
2024 BMW M1000XR
A100man
PostPosted: 09:10 - 24 Apr 2024    Post subject: Reply with quote
who won?
TravisBickle
PostPosted: 13:25 - 24 Apr 2024    Post subject: Reply with quote
I did!
Thanks for asking.
Initially it was very temperamental despite roughing up the contact areas but I think there was a load of rust flakes swimming in WD40 potentially getting between the contacts so disassembled the switch, cleaned and dried it and removed any debris. Works fine now.
2024 BMW M1000XR
The last post was made 2 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 52.91 Kb
