Coolant Check
DaddyStu
PostPosted: 20:44 - 23 Apr 2024    Post subject: Coolant Check Reply with quote
Just done my coolant change but forgot to re-check the radiator level after running the bike upto temp.
Presume the rad sucks up what it needs if it's a little low?
Would just pop the cap off and have a look but the little grubber bolt is a pain to get to behind the fairing.
I did pour in slowly, squeeze the pipes, wobble bike etc before putting the cap on getting a couple of burps. Also it took the 1.8L stated in the manual.
Daddystu
Zontes 125-G1 (part-ex'd). Yamaha Tracer 700.
Easy-X
PostPosted: 20:55 - 23 Apr 2024    Post subject: Re: Coolant Check Reply with quote
Keep an eye on the temperature gauge, fan kicking in... the usual stuff. It'll be fine.
blurredman
PostPosted: 09:21 - 24 Apr 2024    Post subject: Reply with quote
If the radiator doesn't leak, then the vacuum should draw what it needs from the reservoir when the engine is cooling down (could take an hour or more), providing it has adequate enough fluid in it?
MCN
PostPosted: 03:23 - 07 May 2024    Post subject: Reply with quote
Don't follow advice from a forum.
Follow OEM manuals.
Some systems will fill without much trouble.
Some systems require very specific procedures to ensure all trapped air is removed.
Air is a poor conductor of heat energy.
Trapped air next to a 'Hot Spot' of an engine can permit uneven expansion of materials.
That can cause permanent distortion or cracking.
Gaskets can fail and or major components cylinder head, cylinder block.
It's not uncommon for layfolk and pseudo/mock mechanics to fuk up engine by application of lore.
'Usually' a system will eventually push out any trapped air if left to stand.
It really depends on the way the engine designers were feeing.
Some design considers ease of manufacture as critical. And a maintenance procedure will resolve filling issues.
RTFB (Read the fuking book.)
The last post was made 2 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 41.81 Kb
