| pdg |
 pdg World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
 Posted: 17:05 - 06 May 2024 Post subject: |
| pdg |
| WD Forte |
| Nobby the Bastard |
| pdg |
| pdg |
| Nobby the Bastard |
| pdg |
 Posted: 19:26 - 06 May 2024 Post subject: |
| Nobby the Bastard wrote: | Could be worse, could be better.
The little bastard being diagnosed as ADHD has been a bit of a bastard, what with the threats to expel him etc. at 8.
Wht you are looking at on that diagram for the indicator relay is the 'Interrupter Da Embreagem' (excuse my portugese....) |
As long as it could be worse then that's a good day!
Yeah, found the flasher relay, but that's not the only issue I'm working out and tbh the flasher is just an amusing aside - the actual indicators are wired similarly (although they did at least put tape on those) and the flasher fuse keeps blowing. That's easy enough to fix though, it's simply a case of fixing it.
There's a relayesque thingy next to the flasher unit that flutters when I press the start button and the starter will not engage (unidentified so far, it's not the starter solenoid as that's elsewhere, ditto the reg/rec, the starter motor functions fine when I bypass the solenoid with the universal key aka tent peg and starts the bike, the bike runs fine).
It was the intention that it'd be quicker to look at a diagram to identify and test these parts rather than do it through experimentation, but that route is proving elusive... ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
| Nobby the Bastard |
| pdg |
| pdg |
| Nobby the Bastard |
| pdg |
| Nobby the Bastard |
| pdg |
 Posted: 22:43 - 06 May 2024 Post subject: |
Red on green is usually neutral light on a honda. Red on yellow is usually starter trigger.
This probably isn't helpful...
First thought is it's a starter relay used to trigger the solenoid which incorporates a neutral safety lockout. If it is, I'd expect the red on yellow to be live when the starter is pressed and the red on green to be earthed when the bike is in neutral.
That leaves two other wires, black is usually a switched live feed of some sort on a honda so I'd guess the white on blue goes to the solenoid.
Or I could be wrong. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| pdg |
| pdg |
| WD Forte |
| pdg |
| pdg |
The last post was made 2 years, 154 days ago. Instead of replying here, would creating a new thread be more useful? |
