2015 YBR125 loss power and burnt out spark plug
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
pdg
PostPosted: 10:01 - 09 May 2024    Post subject: Reply with quote
MCN wrote:
Suk Me.
You horrible little man.
It's 2024.
Whitworth is 1884.
Devised by Joe Whitworth.
It is NOT a motor vehicle size.
It is a size that may be found in one or two areas of a motor vehicle.
Your obvious display of non-awareness suggests that you believe everything is universally understood.
In addition:
You maintening your Cock Measuring Campaign on here is noted.
If you are not satisfied with your dimensions, may I suggest that you seek help/advice from an appropriate mental health professional.
Member Disphoria. (Thinking one is 'Bigger' than what's the case)
I hope that helps. Thumbs Up
So, seeing as you edited I feel the requirement to reply.
Who rubbed sand in your vagina this morning?
If I thought it was universally understood I would've said something along the lines of "dur, everyone knows xyz", but I didn't.
Instead, I helpfully implied that if you're holding a spark plug with a 10mm thread, chances are you need a socket matked "10mm S P." (there are different standards in use, but the ones most people are likely to come across follow this convention).
Complaining it's an old convention is a bit self important of you - do you bemoan how almost every M8 fastener in the world uses a 13mm hex, except when the Japanese decide to use 12mm or 14mm (often a mix of all 3 sizes) just because they can? Or how they thought "it'll be fun to grind the tip off this Philips screwdriver and introduce a new and incompatible standard that you can't easily differentiate "?
The fact that my renewed presence has made you feel so inadequate that you feel the need to personally attack me speaks more about you than it does about me.
Anyway, I'm off to enjoy the sun.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
PostPosted: 14:43 - 09 May 2024    Post subject: Reply with quote
He's only bitter because he knows Whitworth is the original and the best.
You should sneak round his house and replace all his BMWs M5 torx-head bolts with 2BA cheese-heads.
MCN
PostPosted: 15:05 - 09 May 2024    Post subject: Reply with quote
/\ Rated that comment as Blatent Flame.
Redacted as mods privileges aye prevail. Rolling Eyes
Mark my words.
My Flounce will be in the post.
pdg
PostPosted: 15:39 - 09 May 2024    Post subject: Reply with quote
2nd class post I assume, with a half licked stamp you peeled off another envelope?
Edit to add:
inb4 "it's 2024, we don't lick stamps nowadays, ree, mewl, etc"
MCN
PostPosted: 19:58 - 09 May 2024    Post subject: Reply with quote
Edit to add:
Lick?
It's not penny post M8.
I have one of those 'wetted sponge' things in a dish thing on my writing bureau wet sponge thing drawer.
Edited coz my phone is a prick.
pdg
PostPosted: 20:06 - 09 May 2024    Post subject: Reply with quote
MCN wrote:
Lick?
Wet sponge?
Dang, how old are you?
I thought all stamps were self adhesive now...
(I shall not enquire why your sponge is wet, what it is wet with and what purpose it serves now that stamps and envelopes stick themselves Shocked )
I shall preserve my innocence and presume you enjoy utilising vintage stamps.
bazzaboy2010
PostPosted: 17:54 - 24 May 2024    Post subject: Reply with quote
pdg wrote:
See how this looks different?
OK i did a compression test today and it was at 150 so compression is good, but i can really smell fuel i have had a look around to see if i have a leak and nothing, any ideas?
pdg
PostPosted: 19:59 - 24 May 2024    Post subject: Reply with quote
I assume you didn't disable the ecu before doing the compression test, and that you used the electric start to spin the engine.
A strong smell of fuel is perfectly normal in that circumstance, especially if you held the throttle open to do a compression test as you should do...
So, what I'd do:
Have a look down in the combustion chamber with a camera, if that looks serviceable (and because it has compression) I'd verify spark, check the threads aren't buggered, (properly) fit a new genuine plug and see if it runs.
If it runs I'd then stick a gasalyser on it (or a sparktune) to make sure it's not running ridiculously lean.
If that all checks out, I'd then use it and not worry much - partly because I'm a bit of a hack.
The last post was made 1 year, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 61.96 Kb
