2013 Vespa won't start - help?
TravisBickle
PostPosted: 22:17 - 09 May 2024    Post subject: 2013 Vespa won't start - help? Reply with quote
Got a mate with a 2013 Vespa.
Been sat for 2 years and hasn't budged an inch.
He wants to get it back on the road but it won't start.
He's put a new battery in it and we've tried jump starting it, no good.
Ignition and lights come on and you can hear what I assume is the fuel pump priming, but when you hit the start button - nothing.
20 amp fuse next to the battery is fine.
Haven't delved any deeper than that but anyone know anything obvious we should check before trailering it to a mechanic?
Help/advice will be greatly appreciated.
2024 BMW M1000XR
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport
Nobby the Bastard
Harley Gaydar
PostPosted: 22:20 - 09 May 2024    Post subject: Reply with quote
Have you tried checking if there is fuel in the tank? A lit match should give you enough illumination to see.
Triumph Sprint ST 1050
WD Forte
PostPosted: 23:48 - 09 May 2024    Post subject: Reply with quote
This could go on ad nauseum but anyway
You do realise you have to pull the back brake lever in while starting and
if not and/or the side stand is down you'll get nowt?.
bikers smell of wee
TravisBickle
PostPosted: 23:58 - 09 May 2024    Post subject: Reply with quote
Not my bike.
Only had a very brief look at it in the dark.
Kinda wanted to get it sorted though as I've offered to trailer it if can't get it going himself/ourselves.
He did say the rear brake has to be pulled in which he was doing. I didn't see a side stand but it was up on the centre stand and I asked if it would start on the centre stand and he said yes.
Do these have a side stand? Could be an iffy switch...
2024 BMW M1000XR
PostPosted: 08:54 - 10 May 2024    Post subject: Reply with quote
If it starts on the centrestand it's the f'in sidestand switch. It's not rocket science.
That would also have been important information to include in the original post.
pdg
PostPosted: 09:44 - 10 May 2024    Post subject: Reply with quote
I interpreted it to mean that "yes, it is usually possible to start it while on the centrestand as it has no interlock" as opposed to "it runs on the centrestand now".
Maybe?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
TravisBickle
PostPosted: 10:13 - 10 May 2024    Post subject: Reply with quote
It doesn't have a side stand.
2024 BMW M1000XR
slowasyoulike
PostPosted: 00:59 - 11 May 2024    Post subject: Reply with quote
Details please... '2013 Vespa' covers a multitude of sins. For example, if it's a GTS or some such it would have left the factory with a side stand, so in that case it's possible that the stand wiring/switch might still be there.
TravisBickle
PostPosted: 10:10 - 11 May 2024    Post subject: Reply with quote
Good point!
No idea (not really my cup of tea).
Had to ask.
Vespa Primavera 125 3V.
No side stand apparently.
2024 BMW M1000XR
pdg
PostPosted: 10:47 - 11 May 2024    Post subject: Reply with quote
Generic stuff that I'd do as I have nothing vespa specific to offer...
Quick scan over to make sure no wiring is hanging loose or been chopped up (aftermarket accessories etc.)
Then.
Bypass starter solenoid to check the starter works and engine turns, it may start doing this.
Then.
Verify trigger voltage for the starter solenoid, and check operation if voltage is present, further investigation up to the button if not, including interlocks (brake switch etc).
You say you've tried jump starting - to verify terminology, jump starting is attaching an external voltage source (battery, another vehicle) - is this what you tried?
I'm happy to continue, but you have to consider at what point it becomes far less hassle to wash your hands of it and hook up the trailer...
TravisBickle
PostPosted: 23:32 - 24 May 2024    Post subject: Reply with quote
Then.
Then.
Thanks for the tips that would have been very useful if he hadn't decided to wash the bike and suddenly it now starts.
I'm assuming an iffy rear brake switch in the lever was the culprit and washing the bike disturbed it just enough to make contact.
Thanks to everyone who contributed, especially Nobby!
2024 BMW M1000XR
pdg
PostPosted: 02:58 - 25 May 2024    Post subject: Reply with quote
Go round now and throw mud at it to see if it stops starting again - it's scientifically justifiable.and quite honestly it's your ethical duty. Imagine what a pickle he'd be in if he rode near a field and it stopped working.
The last post was made 2 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 74.52 Kb
