cant get sliding pin out of rear calliper on benelli bn125
PostPosted: 15:18 - 13 May 2024    Post subject: cant get sliding pin out of rear calliper on benelli bn125 Reply with quote
ive tried to do this because the brakes are binding slightly and i think it is the pin. i was advised this by my mot mechanic. do these things come out? or are the permanently heat sealed in there? ive tried mole grips and a spanner to try and turn out the pin. also i have tried pulling the thing apart. i also tried oiling it inside the rubber boot. no joy...
the calliper on the benelli bn 125 is a bit odd compared to other bike callipers, i think..
and yeah the pin doesnt move
pdg
PostPosted: 16:47 - 13 May 2024    Post subject: Reply with quote
pics?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
pdg
PostPosted: 16:50 - 13 May 2024    Post subject: Reply with quote
I say pics because having had a look there appears to be a couple of versions - although none of the ones I've found look anything unusual...
777
PostPosted: 16:54 - 13 May 2024    Post subject: Reply with quote
mine is a 2019 model
unfortunately i dont have a picture of one dismantled
pdg
PostPosted: 17:02 - 13 May 2024    Post subject: Reply with quote
Yeah, that's just a single sided caliper, nothing odd about that.
It's supposed to slide on the pin/bolt because that's how it centres, and the pin should come out by hand (just) if it's functioning correctly.
If it's that stuck, then it'll likely take a combination of penetrating oil, heat and excessive force to remove it, and even after all that there us the possibility that the caliper is scrap. I'd wager the pin is definitely ruined by the corrosion already.
777
PostPosted: 17:03 - 13 May 2024    Post subject: Reply with quote
this is not my calliper its just a picture i got off google. mine is in much better shape
MCN
PostPosted: 17:04 - 13 May 2024    Post subject: Reply with quote
Looks awfy like it's been 'over greased' as they say in maintenance circles.
When was the last time you remembered there was a rear brake?
If you neglect it some more it will maybe drop off.
pdg
PostPosted: 17:07 - 13 May 2024    Post subject: Reply with quote
Better shape externally maybe.
Internally? Your slide pin is rusted/seized in place though, so your floating caliper no longer floats...
It's possible to polish a turd if you dry it out - so while it's shiny on the outside it's still shit in the middle Wink
Robby
Dirty Old Man
PostPosted: 18:12 - 13 May 2024    Post subject: Reply with quote
If it's the pin on the left hand side of your first picture, it looks like it takes an allen key to undo.
Generally in one piece calipers the pin either screws in, or presses in and is retained with a clip.
You can always buy a new one to get an idea of how it fits, then cut out the old one. Sometimes they seize in place, cutting out the middle section makes it easier to remove the bits.
777
PostPosted: 01:59 - 14 May 2024    Post subject: Reply with quote
yeah ive managed to undo this one, its just a kind of nut.
also those pins dont seem to be available to buy anywhere
MCN
PostPosted: 08:37 - 14 May 2024    Post subject: Reply with quote
You need to look for a new or used calliper assembly.
They are probably not considered consumables as manufacturing them use the most economic method and materials.
Ebay-Ing at £30.
Stop facking about.
Robby
Dirty Old Man
PostPosted: 21:43 - 15 May 2024    Post subject: Reply with quote
The pins will be available, but you probably need to get creative in looking for parts.
It's a basic caliper, used on loads of bikes, probably a nissin or tokico one. You just need to find another make/model with the same caliper and proper spares support to buy the part.
Kawasaki Jimbo
PostPosted: 22:29 - 15 May 2024    Post subject: Reply with quote
Oddly it looks like they’re sold out but I think it might be an Allen head M10 x 28mm.
If you’ve managed to remove it, get a bolt measuring tool
(eg. https://www.pro-bolt.com/pro-gauge-bolt-measuring-tool-progauge/?srsltid=AfmBOor1lko7c0bicJUC3g3Jlxcy7u4BIVuJD4Ff9GeQOxYRPC5LqXdyxxc)
and then search for the right diameter, pitch and length on
https://www.westfieldfasteners.co.uk/
or a similar supplier.
sickpup
Old Timer
PostPosted: 04:14 - 19 May 2024    Post subject: Reply with quote
Its a threaded pin, use an allen key. If that doesn't work try heat. If that doesn't work take the caliper off and use heat and an impact driver.
777
PostPosted: 12:30 - 29 Jun 2024    Post subject: Reply with quote
fixed it. it was also one of the pistons. it was a bit stiff, so gave it a good clean with a wire brush drill attachment
The last post was made 2 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 86.68 Kb
