First 125 and no idea what’s wrong
Lukej90
PostPosted: 18:35 - 23 May 2024    Post subject: First 125 and no idea what’s wrong Reply with quote
Hi, just getting into bikes, I bought a 2017 mutt mongrel 125, bliss for a couple of weeks and Monday evening it decided it would start to backfire extremely loud, and vibrate in higher rpms. Since that happened the exhaust has got louder, and deeper sounding, the revs fluctuate on their own and it’s sluggish. I’ve checked spark plug, bone dry and clean, new battery, all hoses and wires clean and correct, any ideas on what to check first?
PostPosted: 19:00 - 23 May 2024    Post subject: Reply with quote
First thought is your exhaust has come loose or is leaking somehow.
When you say it backfires, when does it do this? A classic symptom of a leaky exhaust is popping and banging on the overrun (so when you've been riding along then close the throttle).
Nobby the Bastard
Harley Gaydar
PostPosted: 19:01 - 23 May 2024    Post subject: Reply with quote
If the exhaust has got louder I would.... check the exhuast is still connected correctly...
Triumph Sprint ST 1050
Lukej90
PostPosted: 19:24 - 23 May 2024    Post subject: Reply with quote
Exhaust is connected corrrectly, had a new gasket prior to my owning, checked for leaks and nothing. Backfiring happens anytime, changing up gear, over run, even just starting
Nobby the Bastard
Harley Gaydar
PostPosted: 19:36 - 23 May 2024    Post subject: Reply with quote
Have you taken the baffle out?
Lukej90
PostPosted: 19:42 - 23 May 2024    Post subject: Reply with quote
No, standard exhaust, happened whilst riding, and it has been cutting out a lot previous
Easy-X
PostPosted: 19:50 - 23 May 2024    Post subject: Reply with quote
Double check the air box and filter are all connected/seated. After that I'd probably check the fuel is flowing correctly but I'm not familiar with that particular bike. Older bikes you'd just pop the fuel hose off the carb, into a jam jar and open the petcock then eyeball the fuel flow.
Lukej90
PostPosted: 20:21 - 23 May 2024    Post subject: Reply with quote
As far as I’m aware engine is a Suzuki gn125 replica, fuel injected
WD Forte
PostPosted: 20:56 - 23 May 2024    Post subject: Reply with quote
Engine is K157FMI a GN125 clone to euro 4 spec as used on a shit ton of other chinese made bikes
Mutt just bolt on hipster cosmetic stuff to make it more 'cool'
As its EFI the first step should always be to get an OBD reader
and check the fault codes
bikers smell of wee
PostPosted: 22:16 - 23 May 2024    Post subject: Reply with quote
A tight tappet would do it too. Should be an easy visual check of the clearance, or a compression test if you've got a compression tester.
struan80
PostPosted: 22:26 - 23 May 2024    Post subject: Reply with quote
Nice looking little bike. Hope you get it fixed soon.
The last post was made 2 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 65.56 Kb
