Battery light flashing on Lexmoto Zxsf 125 efi
iJoker20
PostPosted: 19:05 - 23 May 2024    Post subject: Battery light flashing on Lexmoto Zxsf 125 efi Reply with quote
Hello all, the battery light has been flashing on my bike when the ignition is on but it starts up and runs fine, once running there'd be no warning lights on the dash. Sometimes there'd be a hesitation to start as in it would go to, stop then go again and fire up. Now yesterday it started up I went to work, finished work then it was flat.
The battery fitted is a 12v 4ah battery, is the battery light flashing because its not getting charged or because of a faulty battery? As the battery light doesn't flash once its running I'd assumed it would be the battery having to low of an amperage. Any help would be appreciated!
Nobby the Bastard
Harley Gaydar
PostPosted: 19:24 - 23 May 2024    Post subject: Reply with quote
Is it flashing in a sequence? Sounds more like the bike is giving you a fault code.
Triumph Sprint ST 1050
Easy-X
PostPosted: 19:53 - 23 May 2024    Post subject: Reply with quote
I'd imagine the battery light should come on when you turn the key and go off once the engine's started just so you know the light is actually working.
Flat battery hints at the charging circuit, maybe a bad regulator?
Nobby the Bastard
Harley Gaydar
PostPosted: 20:00 - 23 May 2024    Post subject: Re: Battery light flashing on Lexmoto Zxsf 125 efi Reply with quote
Not a flat battery.
iJoker20
PostPosted: 21:00 - 23 May 2024    Post subject: Reply with quote
So the light just continuously blinks until the bike is started
WD Forte
PostPosted: 21:07 - 23 May 2024    Post subject: Re: Battery light flashing on Lexmoto Zxsf 125 efi Reply with quote
First thing to check is the battery terminals are clean and properly fastened
Next is to put a meter on it to observe the standing voltage
say 12.5V
and running voltage, typically around 14v
bikers smell of wee
Easy-X
PostPosted: 22:12 - 23 May 2024    Post subject: Reply with quote
Okay, I take it back. Lights might come on all at once as a "lights test" but not flashing, that's something else.
iJoker20
PostPosted: 22:13 - 23 May 2024    Post subject: Reply with quote
I removed the battery today in the hopes of finding a replacement or one similar so I've made sure the terminals were tight and secure. I'll use a multimeter and check voltages tomorrow
The last post was made 2 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 55.01 Kb
