Honda CG Head drilling for carb
Ross47888
PostPosted: 19:17 - 27 May 2024    Post subject: Honda CG Head drilling for carb Reply with quote
Hi, so I bought a 1978 Honda CG. It has a 1984 CGE engine in it, that the owner said was just rebuilt with a new piston (first warning sign). Turns out the engine was almost certainly not rebuilt, and it seized less than 10 miles after buying it, top end seizure. I'm living in Andover atm but I can't work on the bike here, so I brought the engine in suitcase home by bus / boat to Northern Ireland to work on it.
After looking at the piston etc I ordered this head and barrel kit off ebay https://www.ebay.co.uk/itm/352716574424?itmmeta=01HYXQ6HP2HQAYVXNF0EJ1MQS5&hash=item521f8bced8:g:LZEAAOSwRKtciOSr
Problem is the this bolts for the carb on this head don't line up with with the original carb / head. Since it's just aluminum am I fine to just drill it out, tap it and run carb through the new holes? Picture should be attached comparing two different heads.
So am I fine to use this head if I drill two bolt holes for the carb or tilt it on its side? Or do I need a new head. Thanks.
WD Forte
PostPosted: 20:54 - 27 May 2024    Post subject: Reply with quote
As long as the holes aren't too close to the edge of the milled casting to cause weakening then yes.
Dont tilt the carb, it wont like it.
I feel a bit leery if this 'Genuine Honda' thing on Ebay
the bike doesn't even have honda badges on it and looks like
a Pakistan honda not Japanese honda which the listing could lead you to believe
Plus the carb on that bike has level carb studs, not tilted ones.
It may fine for all that and i'm not an expert on all things CG so hope it works out for you
bikers smell of wee
PostPosted: 22:27 - 27 May 2024    Post subject: Reply with quote
I bet that was a new piston. Just the wrong size.
And yes, if there's enough metal there, I'd drill and tap.
EDIT: Port diameter looks smaller on the new head.
Evil Hans
PostPosted: 08:32 - 28 May 2024    Post subject: Reply with quote
Or get a flange adapter? Something like this might do it?
https://www.ebay.co.uk/itm/204714139801
Ross47888
PostPosted: 15:07 - 28 May 2024    Post subject: Reply with quote
Alright great thanks. I'm also a bit suspicious of "genuine" Honda. Since it doesn't fit my bike I think it's probably not a Japaneses built engine, (although I don't know what the type of fitting the Japanese CG reruns had for their carbs). I can't really check either as I'm in England atm and my dad is opening the stuff for me. I'll probably end up giving it a try and if it doesn't work, use the original head.
Alright sweet thanks. Yeah maybe it was the wrong size, but he guy I bought it off gave me the original piston that came with it - that he changed, and they were the same size. The piston had no play on the gudgeon pin at all though and was basically seized on.
Thanks, that's pretty cheap so I'll give it a go first, although from what I remember wasn't a whole lot of room when everything is in. But it's cheap enough to not lose anything trying.
cresad
PostPosted: 21:34 - 28 May 2024    Post subject: Reply with quote
Just make sure you don't go to deep , saw similar on daughters ybr and it broke through into the oil way.
Adam
PostPosted: 07:51 - 29 May 2024    Post subject: Reply with quote
I think, going from some diagrams, that's a 1995 or CG S model. Only one with vertical mount holes. Everything 81 onwards till then appears to be horizontal.
https://www.cmsnl.com/honda-cg125-1995-s-england_model2608/partslist/E__0100.html
Weirdly carb is listed as a horizontal hole mount...all list different jet and float sets too, which ties in with a smaller carb hole that Stinkwheel mentions. I imagine they changed a few things.
WD Forte
PostPosted: 13:11 - 29 May 2024    Post subject: Reply with quote
Broadly speaking CG here
78 bike 84 engine that's still 6v electrics and points ignition right?
I dont think they went 12V CDI until the 90s?
bikers smell of wee
blurredman
PostPosted: 14:11 - 29 May 2024    Post subject: Reply with quote
'85 when they got to 12v not sure about CDI though.
Rob Fzs
PostPosted: 15:49 - 29 May 2024    Post subject: Reply with quote
they were 12v points in 92' on the Brazilian ones/ coffin shape tank
then they moved to cdi with the round shape tank
back in the day, (14 years ago) i fitted an 07 engine in a 92' frame and it fitted fine, obviously needed new loom and the airbox didn't line up with the carb but i made adjustments with some heat shrink tube....
'00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30> Yamaha RD350 YPVS F2 > Kawasaki ZZR 600 D1 > Yamaha TZR 250 2MA >Suzuki TL1000R > Yamaha TDR250 > Honda 929 blade > Suzuki SV1000 > Honda H100
Mod 2 Passed 09/06/2011
Ross47888
PostPosted: 22:23 - 03 Sep 2024    Post subject: Reply with quote
Just came back to say, this worked well for me. Only downside is it puts a lot of stress on the stock hose from air box to carb.
The last post was made 2 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 72.39 Kb
