| Freddyfruitba... |
 Freddyfruitba... World Chat Champion
 Posted: 19:02 - 27 May 2024 Post subject: Fixing my leaking boots |
My boots (TCX Classic/Explorer EVO Goretex) have started leaking, presumably due to the soles beginning to come away from the uppers - see photo. Other than that they're in great nick so I'm reluctant to bin them if I can help it. Anybody have any good suggestions for resealing? I did try using a builder's silicone sealant, having tried to clean out the gap first with meths, but it didn't hold at all.
Any better ideas? Other than to stop being a cheapskate?
https://i.postimg.cc/C14tzyjq/boot.jpg ____________________ KC100->CB100N->CB250RS--------->DL650AL2->R1200RS->R1250RS |
| struan80 |
 struan80 World Chat Champion
 Posted: 19:07 - 27 May 2024 Post subject: |
Without any scientific reason I would use superglue. Just make sure you're feet are out of the boots when applying.
Cheapskate |
| Nobby the Bastard |
| doggone |
 doggone World Chat Champion
| Minty |
 Minty World Chat Champion
| stinkwheel |
 Posted: 20:19 - 27 May 2024 Post subject: |
A non-expanding polyurethane adhesive like gorilla clear (not normal gorilla, it foams up and will push it apart again). Find a way to hold the bit you are gluing down as firmly as possible while it sets up. A clamp and some bits of wood wouldn't be overkill but some tape at a bare minimum.
Or sealskinz socks. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| Ste |
 Ste Not Work Safe
| MCN |
 MCN Super Spammer
| A100man |
 A100man World Chat Champion
 Posted: 12:43 - 28 May 2024 Post subject: |
As a pathelogical tight-wad I have successfully fixed new soles to trainers with good uppers (my favourite Gola Harrier high -tops) and prior filled to worn heel with this stuff..
https://www.toolstation.com/stixall-adhesive-sealant/p60981
It's the tits cos flexible and you get loads of it. The downside its that it takes about 24Hrs to properly go off - depending on thickness of application. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Freddyfruitba... |
| MCN |
 MCN Super Spammer
| Freddyfruitba... |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| Islander |
 Islander World Chat Champion
| stinkwheel |
| A100man |
 Posted: 10:02 - 29 May 2024 Post subject: |
| stinkwheel wrote: | | A100man wrote: | As a pathelogical tight-wad I have successfully fixed new soles to trainers with good uppers (my favourite Gola Harrier high -tops) and prior filled to worn heel with this stuff..
It's the tits cos flexible and you get loads of it. The downside its that it takes about 24Hrs to properly go off - depending on thickness of application. |
Cheap non-foaming polyurethane adhesive.
| Islander wrote: | Stormsure repair adhesive. It's intended for this sort of thing and works brilliantly. You'll have to improvise a method of clamping it closed and holding it but it won't leak any more if you do it correctly.
You can even build up worn heels with the stuff. |
Expensive non-foaming polyurethane adhesive. |
By a factor of more than 20x I note... ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Islander |
The last post was made 2 years, 140 days ago. Instead of replying here, would creating a new thread be more useful? |
