Suzuki TS50 will not start
Farmingstock
PostPosted: 21:12 - 03 Jun 2024    Post subject: Suzuki TS50 will not start Reply with quote
As title says I cannot get the thing to start, the plug is constantly dry, fuel is getting to the carb fine, just not getting to the cylinder, all jets and pathways in carb are clear, tried an auxiliary tank, brand new plug, kicked over hundreds of times it’s not started once, reeds are fine, no cracks and seal fine., plenty of compression!
If I put fuel into the cylinder it still doesn’t start!
A100man
PostPosted: 13:15 - 04 Jun 2024    Post subject: Reply with quote
Squirt soem carb cleaner into the intake (or EasyStart) at least you can then eliminate timing if it starts.
c_dug
PostPosted: 15:06 - 04 Jun 2024    Post subject: Reply with quote
I had a TS50x as my first bike, long time back now.
Mine also wouldn't start, and confusingly despite it being a kick start the thing that made the difference was a new battery - worth checking yours?
blurredman
PostPosted: 16:10 - 04 Jun 2024    Post subject: Reply with quote
Indeed- kick start doesn't necessarily mean 'self-exciting'.
We don't know what specific year or variation of TS50 this is?
PostPosted: 16:46 - 04 Jun 2024    Post subject: Reply with quote
How do you know the crank seals are fine?
Farmingstock
PostPosted: 19:02 - 04 Jun 2024    Post subject: Reply with quote
Took the carb of completely and squirted some carb clean into the intake, (not ideal but the bike was a none runner and I’m almost cured of it now) the bike didn’t start as such just popped over like it was misfiring, I have taken the flywheel off to checked the woodruff key all seems fine, however the stator looks like it’s on the very limit counter clockwise, there are no markings to centre it up, but looks like it’s way to advanced, the screws are of course threaded and won’t loosen so I’m going to have to order an impact driver! Tried hitting the end of a screwdriver whilst turning it but no joy!
There is plenty of spark on the brand new plug, so no battery issue as I’m kicking it over, compression is fine, so fuel or timing related, I’m guessing timing as the spray only caused a pop/ran for under a second!
Farmingstock
PostPosted: 19:17 - 04 Jun 2024    Post subject: Reply with quote
It’s a TS50X 1984
Nobby the Bastard
Harley Gaydar
PostPosted: 19:27 - 04 Jun 2024    Post subject: Reply with quote
As a 2T the only timing is on the ignition. If electronic there is no timing adjustment available typically, if points the adjustment is on the poinnts gap.
Triumph Sprint ST 1050
Farmingstock
PostPosted: 20:21 - 04 Jun 2024    Post subject: Reply with quote
https://www.cmsnl.com/suzuki-ts50xk-1984-e-e02-e16-e18-e21_model14157/partslist/FIG13.html
Can you see the area of adjustment for the 3 screws no.11
PostPosted: 23:40 - 04 Jun 2024    Post subject: Reply with quote
A good way of cracking those screws free is using a screwdriver bit in an old fashioned hand drill brace. You can then push into the screw head with your chest on the end of the brace and crack it loose with the handle.
Not really a true statement in any respect. It's true of some but I'd say not of most.
Most 2t ignition timing with points is achieved by rotating the stator plate on slots. Only the really basic ones have a fixed points plate. Take this from someone who had to maintain a Kawasaki triple for his Dad where ignition timing had to be done every 500 miles or so by adjusting three seperate, stacked stator backing plates for three sets of points.
I've seen more than a few electronic ignitions with slotted hall effect sensor mounts.
You can also have port timing, especially with crankcase induction disc valve engines. The T50 isn't one but eg a FS1E/YB100/RXS100 is.
Farmingstock
PostPosted: 15:09 - 05 Jun 2024    Post subject: Reply with quote
Got the stator plate off after drilling the screws out and behind it was the crankcase seal fallen out! I’m going to replace this now but I’m guessing that wouldn’t help matters.
Top end compression was fine, but may explain why the carb wasn’t sucking any fuel in
Farmingstock
PostPosted: 18:54 - 06 Jun 2024    Post subject: Reply with quote
Put the new crank seal in and it starts perfectly! Hallelujah!!
Thanks for the advice guys!
blurredman
PostPosted: 08:37 - 07 Jun 2024    Post subject: Reply with quote
Congrats! Cool
The last post was made 2 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 77.62 Kb
