| ALS96 |
 ALS96 L Plate Warrior
 Posted: 17:19 - 03 Jun 2024 Post subject: |
Is the misfire apparent at a particular throttle position? An airbox leak could certainly cause issues at middle to higher rev speeds.
Rusty frame earths on the ignition coils seem to be a common issue on older kawasakis.
When were the plugs last changed?
EDIT: I've had problems on an older kawasaki with ethanol corrosion on the carb needle valves causing them to stick both open and closed. Modern viton-tipped replacements are available. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 Posted: 17:22 - 03 Jun 2024 Post subject: |
With regard to parts, depends on what parts. If it's an airbox, a good 2nd hand one off ebay would be my goto.
For service parts, I usually use wemoto.
For carb parts, I generally see if I can get them from Allens Performance, then you know you're getting genuine keihin parts. You usually can unless they are very model specific. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ALS96 |
| Kawasaki Jimbo |
 Posted: 18:48 - 03 Jun 2024 Post subject: |
If it's an idle problem, it's probably not the airbox. Could be a loss of spark or could be a blocked pilot jet. I generally investigate the spark aspect first because that's more common and 90's kawasaki carbs and airboxes are a PITA to get off and on again.
For fork seals and bushes, I'd go for OEM even though they are 2-3 times the price. Pattern ones seem to be about 50:50 if they last more than a few weeks and the bushings are never a good fit. Wemoto stock them.
Or order them from fowlers or similar. Or search for the part numbers.
Fork seal part number: 920491363
Inner bushing: 440651080
Outer bushing: 440651079 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ALS96 |
| ALS96 |
| ALS96 |
| struan80 |
 struan80 World Chat Champion
 Posted: 22:20 - 04 Jun 2024 Post subject: |
Although I appreciate your post. It is irrelavent without photos of bike.  |
| A100man |
 A100man World Chat Champion
 Posted: 12:43 - 05 Jun 2024 Post subject: |
| ALS96 wrote: | Evening, that thermometer turned up and cylinder 1-2-3 are running around 50°c when i checked and cylinder 4 was at 58°c, removed spark plugs and 1-2-4 are all shot, 3 was better but not much better. Currently removing the carbs as after speaking to some people they reckon the carbs aren't balanced and need cleaning as well.
Thanks
Arron |
50C ? Did you miss a nought off? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
The last post was made 2 years, 110 days ago. Instead of replying here, would creating a new thread be more useful? |
