| sickpup |
 sickpup Old Timer
 Posted: 16:23 - 06 Jun 2024 Post subject: GVW and Max load on touring Motorcycles |
I've been having problems over the last few years with one of the Deauvilles with the rear tyre sidewalls cracking. I've been in contact with the manufacturer of the tyres who initially put it down to low pressure.
A relatively new rear tyre has now gone the same way, one that has never had more than 2 psi low pressure and no punctures so I looked a little further into it and having discussed it with the tyre manufacturer it now appears the sidewall cracking has in fact been caused by overloading.
The Deauville is a heavy bike at 260kg or so and uses a 69 load rated tyre. The maximum load on the bike which surprised me is only 187kg for the ABS version which I have. This is for a bog standard bike. If you add the various extras such as top box and rack, belly pan, heated grips, hand deflectors, large pannier lids, handle bar muffs, blanket etc you are adding around 20kg weight which comes off the maximum load so instantly you are down to 167kg.
I weigh 118kg naked so add 12kg for clothing and helmet so once on the bike you are down to only 37kg for the pillion and any load in the panniers and top box. Just to save time I am overweight and could do with losing 15kg but I'm also big, just not weight lifter big
The boxes it is recommended only carry 5kg a piece but people tend to carry a lot more but lets assume 15kg for the lot and you are down to 22kg for the pillion.
My other half is 90kg dressed so that would overload the bike by 68kg
Both the ST1100 and the ST1300 have the same type of maximum loads so it is likely that 2 average sized people on any of these bikes would overload them, odd for bikes that are sold as two up tourers but also wipes out the lie that people buy these bikes to carry heavy loads.
I'm going to get around this problem by fitting a larger tyre with a 73 load rating, it'll give an extra 40kg in capacity on the rear tyre which should stop the sidewalls splitting and I'll have to stop carrying heavy luggage which shouldn't be a problem, I have a car now.
It surprised me just how low the maximum load was and just how marginal the overload capacity was on the tyres. |
| MarJay |
 MarJay But it's British!
| sickpup |
 sickpup Old Timer
| MCN |
 MCN Super Spammer
| sickpup |
 sickpup Old Timer
 Posted: 07:50 - 07 Jun 2024 Post subject: |
Never thought about that either. Although I'm aware my old bus is heavy so i fitted the GT version of the road 6 so I'm probably ok.
Having just checked, the GT and standard version have the same load rating of 73 (365kg). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| DaddyStu |
 DaddyStu Crazy Courier
| MCN |
 MCN Super Spammer
| P.addy |
 P.addy Red Rocket
| A100man |
 A100man World Chat Champion
 Posted: 23:22 - 10 Jun 2024 Post subject: |
Average UK weight is now abouy 85kg (13st 5lbs)men and 72 kg (11St 4lbs) women up about 5% in the past 20 years.
People are getting taller but that's quite some heft. I always figured 12 and 9 was about average. No wonder the wankpanzer GSs are so popular. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| sickpup |
 sickpup Old Timer
The last post was made 2 years, 80 days ago. Instead of replying here, would creating a new thread be more useful? |
