| Nobby the Bastard |
| blurredman |
 Posted: 07:34 - 04 Jun 2024 Post subject: |
Bulbs, like everything have become very expensive for what they are. What used to be £2 for a pack of 10 delivered, now I can only get as £4 for one, or £10 for 10. I don't want 10 and paying so much for just a single is a complete rip off, I have no other bikes that will use them. But, I have about 15 festoon bulbs the right wattage and voltage... What was a proof in concept with oversized gauge piggyback spade connections and under-sized wires, will be adjusted to suit at a later date.
https://www.bikechatforums.com/download.php?id=106796 ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 51k. |
| Serendipity |
 Serendipity World Chat Champion
 Posted: 16:56 - 09 Jun 2024 Post subject: |
I continued a hated job I started in mid-May to replace the rotten exhaust headers on my very crusty, high mileage 2007 CBF1000.
4 exhaust studs had come out ok, 2 snapped and 2 had the corroded nuts crumble, but unfortunately left enough nut to prevent the exhaust collar moving.
With the headers still in place there’s not enough room for an angle grinder so I had to cut off the tops of the corroded studs with a Dremel-style multi tool. A slow and laborious job, but ultimately successful.
Removing the headers also means tracing the wiring for the oxygen sensor and unplugging it. That also turned out to be a pain in the arse, involving removal of top box rack, seats, side covers, battery and battery box.
https://i.imgur.com/i2bttTDh.jpg
Then the bike needs to come off the centre stand so the collector box can pass back through the middle of the retracted centre stand. If you move the bike onto the sidestand AFTER dropping the headers it all jams up in the centre stand and makes you think the bike is about to fall on you while you try to manoeuvre pipes out. Ask me how I know! With a bit of trial and error it was all successful and headers finally removed.
| Serendipity wrote: | …Then I'll waste time and effort trying to turn out the 4 stuck studs before I eventually lose patience, cut them off, drill them out and helicoil them.  … |
I have a set of stud removal sockets, but I ran into an instant fail! The external bit of the Honda studs is 7mm and my nearest sockets were 6mm or 8mm. One wouldn’t fit and the other was too large to grab.
https://i.imgur.com/gSaiDsxh.jpg
While hunting online for a 7mm stud extractor I stumbled across the Sealey AK718 which is like a drill chuck on a half inch socket. It tightens and bites into the stud as you turn it. Since it covered any stud from 6mm to 12mm and cost around the same as a dedicated 7mm extractor (£20 ish) I thought I’d give it a go.
It turned out to be an excellent tool. If you find yourself in a situation with a snapped stud with at least a bit still protruding I’d highly recommend giving it a go. Apparently it’s suitable for air impact, but I don’t have such a thing. I just used a half inch socket drive and a big adjustable wrench to really nip it up tight on the stud. Then the suckers all just turned out one by one. Enormously quicker than drilling and Helicoil so a definite win in my opinion.
https://i.imgur.com/Ms1APX4h.jpg
I couldn’t get the socket drive on the highest stud because it fouled on the radiator, but the tool works just as well with a pair of adjustable spanners. The flats are 36mm and 24mm respectively so you need a large spanner, but plumbing grips or a big Stillson should work.
https://i.imgur.com/mjg41jYl.jpg
Then I hooked out the old copper crush gaskets and fitted new ones. I slightly cheaped out and went for stainless studs and nuts from eBay. I know they might be problematic if they have to be drilled out in the future, but with 122,000 miles on the clock I'm hoping this is the first and last time the headers need to come off. Now I just need to fit the 2nd hand eBay headers.
https://i.imgur.com/jWkOxCnh.jpg ____________________ 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
 Posted: 17:44 - 09 Jun 2024 Post subject: |
You got bloody lucky there. Usually they just shear off flush.
Have yourself a beer to celebrate that one. ____________________ a.k.a 'Geri'
| Serendipity |
 Posted: 18:49 - 09 Jun 2024 Post subject: |
Thanks, I do feel lucky.
I've been here before and ended up drilling the stud out. This time I gave myself the best chance by cleaning up each stud with a wire wheel and scratching out as much corrosion as I could with a pick. The bulge in the middle of each stud was desperately trying to become one with the alloy of the block.
I was impressed with that extractor tool though. It gripped the studs really well. ____________________ 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| hellkat |
 hellkat Super Spammer
| A100man |
 A100man World Chat Champion
 Posted: 10:03 - 10 Jun 2024 Post subject: |
| hellkat wrote: | I finally got my finger out of my arse .. |
That's a figure of speech, right? ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
| blurredman |
 Posted: 12:59 - 10 Jun 2024 Post subject: |
Ontop of the AC lighting not working, I realised the battery wasn't being charged on the TS185. I haven't investigated the lighting yet, because it's the day time and the lights aren't needed and I don't have too much time to fix things that aren't needed.
But did find the main fuse was blown. Actually, I think it had failed from vibration or manhandling after the fact - it was quite possibly original at 45 years old and the end caps could be twisted off the glass tube, and no singe marks on the fuse break itself. But notably the brake light did light before I started work, indicating it was I who broke the fuse.
So: cleaned up the fuse holder, installed new fuse and also crimped down the spade connector on the tiny rectifier as the male counterpart to go into it was a little bit loose which was the seemingly obvious reason as for lack of charge in the first instance, but as always. Things break, or develope when you work and sometmies present themselves as red herrings etc. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| A100man |
 Posted: 13:23 - 10 Jun 2024 Post subject: |
| Serendipity wrote: | Thanks, I do feel lucky.
I was impressed with that extractor tool though. It gripped the studs really well. |
you did well.. either that tool is mustard or you had some luck. Did you also use plus gas, heat and rock to and fro? ____________________ Now: A100, GT250A, XJ598, FZ750
| MarJay |
 MarJay But it's British!
| Easy-X |
 Easy-X Super Spammer
 Posted: 16:08 - 11 Jun 2024 Post subject: |
A little experiment with knifeless tape:
https://i.imgur.com/H5LK06r.jpeg
Total failure with my choice of vinyl tape, ended up cutting manually:
https://i.imgur.com/7KZus8A.jpeg
There's some red bits on the Vitpilen forks, thought I'd jazz things up a bit in the white areas. I was going to do the same with the side panels but it looks like I'll have to get some automotive vinyl wrap to work with this knifeless stuff  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| thx1138 |
 thx1138 World Chat Champion
 Posted: 19:40 - 11 Jun 2024 Post subject: |
Full service and MOT. MOT passed, no advisories. Service report included a warning tyres are nearly 10 years old  |
| to v or not to v |
 to v or not to v World Chat Champion
| MarJay |
| blurredman |
 Posted: 09:02 - 21 Jun 2024 Post subject: |
| thx1138 wrote: | Full service and MOT. MOT passed, no advisories. Service report included a warning tyres are nearly 10 years old  |
I had that last year. "you know your tyre is over 10 years old?"
"Yes...."
Infact it's almost 30.
I have noticed my battery was being cooked on one of my bikes. Lights are normally AC. Battery upon checking was being charged 8.7v at full chat. I have decided for a quick and easy resolution to pre-load the battery with pilot light and rear light running from the battery with ignition on to bring down charging rate. I will later change this to the speedo back lights however so that the light switch actually does something... Headlights are for the night time. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| to v or not to v |
| Easy-X |
 Posted: 11:57 - 23 Jun 2024 Post subject: |
Sold the XSR. The fella buying it hasn't ridden for a few years so I volunteered to deliver it to him. Lovely day for a final ride out on the bike; I shall miss the exhaust note the most  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Easy-X |
 Posted: 16:28 - 23 Jun 2024 Post subject: |
More fun with vinyl tape:
https://i.imgur.com/VAipHtg.jpeg
And the great thing is when England bow out in the next round it peels straight off  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| blurredman |
 Posted: 18:34 - 23 Jun 2024 Post subject: |
After finally completing my latest project I was excited to go around the immediate block a few times which I did, and whilst doing so adjusted rear brake cable, clutch cable, gear shift lever, throttle cable tension (controls idle), and was happy with the thing.
So happy that as I was walking away from it to open the garage door the thing fell over. Second time i've done this in the last two weeks. Smashed front indicator lens and a few grazes.
But, did do what I mentioned regarding one of my bikes. Now the speedo backlights take load from the battery so they're always on to reduce charging voltage, and the outward lights themselves only work when I want them to. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| to v or not to v |
| MarJay |
| to v or not to v |
 Posted: 11:15 - 30 Jun 2024 Post subject: |
fitted some Grip Puppies.
if im not impressed with them Freddyfruitbat will be going on my enemies list  ____________________ current bike Yamaha Thunderace.
Moto Guzzi V7. |
| DJP |
 DJP Crazy Courier
 Posted: 16:08 - 04 Jul 2024 Post subject: |
Done nothing to my bike but I did take it for a poodle around the Kent countryside.
Came back to South London to find that I'd done 180 miles.
Fuel map needs a teensy bit more tinkering but otherwise the "Stage 2" tune is looking good and I do love an uncorked Bandit 1250! ____________________ Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https |
| Kawasaki Jimbo |
 Posted: 17:08 - 09 Jul 2024 Post subject: |
Today I fitted new clutch plates and springs to the ZX6R at 70k miles because the original had just started to slip in first and it wouldn’t go into neutral if the engine was running.
Also, I remembered that the clutch cable had snapped at about 35k miles and sure enough, the old one was worn at the ’bar lever. I struggled to fit the new cable at the clutch end and probably took 5k miles off its life during the installation. Ah well, done now, although adjustment isn’t correct yet. Heavy rain and hunger stopped play.
https://i.postimg.cc/qqT126bK/IMG-1442.jpg |
| MarJay |
The last post was made 1 year, 203 days ago. Instead of replying here, would creating a new thread be more useful? |
