Coil impedance concerns - WD Forte et al?
A100man
PostPosted: 11:43 - 11 Jun 2024    Post subject: Coil impedance concerns - WD Forte et al? Reply with quote
OK so new XJ coils from Yellow Square arrive.. but some concerns.
mounting holes are 90mm not 100mm (but could be adapted ) and Primary impedance is 3.9 Ohm whereas factory spec demand 2.5 Ohms,
Supplier is suggesting this higher value won't damage the TCI (Ignitor) box and produces a better spark (secondary is also higher at 15KOhms vs 11KOhms factory.
My knowledge in this area is poor - what do the great BCF minds think?
WD Forte
PostPosted: 15:46 - 11 Jun 2024    Post subject: Reply with quote
Broadly speaking probably be ok.
0.6 ohms higher suggests less primary current
and the higher secondary suggests more windings/higher output voltage
but
Drilling down into ignition function can get pretty complex
even when you have all the circuit details to hand which we don't
Ultimately it comes down to whether it works well and reliably or not
so it's a case of try it and find out
bikers smell of wee
A100man
PostPosted: 15:53 - 11 Jun 2024    Post subject: Reply with quote
Ta muchly
Ill return teh ones I have for ones that actually fit (100mm mounts) and appaer to have a closer [to spec] primary res of 3.0 Ohms. £20 quid more but worth it I think .
The last post was made 2 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 35.49 Kb
