| alan0259 |
 alan0259 Nova Slayer
 Posted: 07:59 - 13 Jun 2024 Post subject: SRAD 600 cuts out when hot - won’t start until cooled down |
Hi all,
Picked up a 600 SRAD project, it fires up perfect (full choke on) and idles perfect (choke off) for around 8 minutes, then it starts to sound a bit groggy and will eventually cut out (temp on dash shows around 90 degrees).
The bike will just about start again (straight away) if I give it lots of throttle and keeping the starter button pushed in, but it just wants to die again straight away.
Checked the battery voltage, it’s 12.8 when turned off, goes to 17v when running (no lights on), drops to 14v with headlights on.
When it struggles to start when hot, the starter motor seems to turn over like a snail, really sluggish (battery boost pack attached helps slightly but still super slow and won’t fire up).
I’ve tried it with and without the airbox. I’ve checked the tank fuel pipes for any kinks, I’ve tried running the bike with the fuel cap off, nothing makes a difference.
Unsure if it’s fuel / electrical, can’t see it being mechanical as it sounds so healthy when cold and starts perfect when cold.
Any help would be appreciated.
Thanks. |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 09:13 - 13 Jun 2024 Post subject: |
17v is too much. Try a different reg/rec ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Nobby the Bastard |
| virus |
 virus World Chat Champion
| MaybeGuy |
| Nobby the Bastard |
| stinkwheel |
| P.addy |
 P.addy Red Rocket
 Posted: 08:15 - 14 Jun 2024 Post subject: |
17v into a battery isn't good, cooked my SV one at about 17, sudden smell of eggs and a very swollen battery. Low 14s is all of everything want, the rest of the wiring and kit might not like being 17+.
Also I saw you mentioned idling, even whilst moving and being covered in plastic, it's still going to have some air flow over or near the coils, minimal but still. Not saying ride it cos battery going pop under your nuts wouldn't be fun, but wonder if you experience the issues with it then, or whether they break down faster being under actual use.
Change reg rec, make sure you see high 13 low 14 at the battery then would replace battery. If you are near me I can probably provide a reg rec, have a box full |
| alan0259 |
| Nobby the Bastard |
The last post was made 2 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
