Mutt Mongrel 125
boothy
PostPosted: 11:17 - 11 Jun 2024    Post subject: Mutt Mongrel 125 Reply with quote
Still looking for my first Bike and have come across this mutt mongrel 125cc. What do people think of the brand? It’s barely been used by the current owner and is going for about 1.2k although it is off the fb market place. What should I check for if I go take a look at it?
https://www.facebook.com/share/9YSYVwFskKuJrhpy/?mibextid=79PoIi
PostPosted: 11:26 - 11 Jun 2024    Post subject: Reply with quote
Tis a Chinese bike rebranded by a European company to sell to hipsters. It may be a small cut above your standard Chinese fare because it may have european quality control, but it still won't be fantastic. Brixton is another similar brand, and I think also the AJS name has been repurposed for this too.
A100man
PostPosted: 11:38 - 11 Jun 2024    Post subject: Reply with quote
Indeed, Herald is another. Incidentally, the British sounding 'Brixton' are in fact owned by some Austrians but the bikes are still Chinese, Mutt I believe are French importers.
PostPosted: 13:37 - 11 Jun 2024    Post subject: Reply with quote
It's a better overall design for a first bike than the cruisers you've been looking at.
As above, still Chinese but with some QC input and spares backup so you could do worse.
I would budget for a set of proper road tyres instead of the things it has on if you value staying stuck to the road over aesthetics. Those big knobblies will be all kinds of unpleasant and something you could do without when you're learning. They are a slightly oddball size (4.10 x 18 front and rear). I'd be tempted to get a good quality road tyre with a 120/90 18 on the rear and a 110/90 18 on the front. Something like a Michelin Road classic or Avon roadrider. Or if you want to keep the knobbly look, a set of Sirac or mitas E08 or similar which appear knobbly but have more of a road bias.
A100man
PostPosted: 13:44 - 11 Jun 2024    Post subject: Re: Mutt Mongrel 125 Reply with quote
Its not stolen.
22 miles only on the clock Shocked
WD Forte
PostPosted: 15:28 - 11 Jun 2024    Post subject: Reply with quote
I'd say its a better choice of first bike because it's simpler with less frills
I believe it has a Suzuki clone engine that should be easy to get parts for.
As said, it's tarted up gn125 and the knobbly tyres are a stupid affectation that need changing for road tyres asap unless you live on a farm
check it's got oil in it and
it should start easily with no smoke or rattles
the mileage looks too good to be true so check the odometer on the
clocks is functional
not a deal breaker if it doesn't and its in otherwise good nick
but getting a new on could be a PITA
Ahh I see it has 'new clocks' fair enough, but one has to wonder why it needed them
bikers smell of wee
Villers
PostPosted: 20:28 - 16 Jun 2024    Post subject: Reply with quote
Not really a surprise, a guy at work has one as his first bike, it's around 18 months old and it's rotting away nicely. The cable that powers the clocks (they are a weird digital thing) frayed through on it's own and caused some havoc Confused
lingeringstin...
PostPosted: 22:31 - 16 Jun 2024    Post subject: Reply with quote
What I've discovered in dabbling with Chinese Honda clones and derivatives is that these days the engines are actually quite good but they keep the prices low by skimping on the quality of everything else.
Chinese chrome is more rustworthy than anything else and the paint jobs are thin and crap. The metals used for frames and things is pretty low budget so they're quick to corrode and rust through. But a newer model should look fine for a few years anyway, just don't expect them to age and hang around for decades like vintage CG125's etc.
However, if you can find something like a knackered Honda to bolt a Chinese engine into (they're cheap to get all over the place even new) then you'd end up with a pretty good bike.
This isn't "the old days" any more when Chinese engines were complete rubbish. What they make as engines for small bikes these days is about as good as anything the name brand companies were doing 20 or 30 years ago and I've found that you can often even mix and match parts from Chinese and Honda engines together which is what I use now. I have an engine that's some kind of Honda/Chinese 50/50 abomination of disparate parts that's every bit as good as anything Honda ever made, but I did have to build it myself and you probably aren't wanting to get into all that faff.
I'd say if you're going with a Chinese bike for the cost factor then get something as uncomplicated as possible, like a CG125 clone (that Mutt looks like the sort of thing). I'd stay away from the cruisers and anything with too many whistles and bells. Less shit to go wrong.
The last post was made 2 years, 76 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 58.91 Kb
