Torque vs. Speed - changing sprockets
Easy-X
PostPosted: 12:30 - 24 Jun 2024    Post subject: Torque vs. Speed - changing sprockets Reply with quote
After dropping off the XSR this weekend I followed up with a ride out on the Husky which was nice given the weather. I'm still enamoured by the latter's lightness - both weight and handling - so I've resolved to go "all in" on its continual refinement.
I'm considering the value of changing out the sprockets. Maybe I go up 4 or so teeth on the rear but that also means a new chain with more links. The alternative is drop a tooth on the front but does that lead to excessive chain wear?
PostPosted: 13:57 - 24 Jun 2024    Post subject: Reply with quote
There is a minimum number of teeth you're supposed to have on a front sprocket to prevent extra chain wear. Going down one tooth on most bikes is fine, but it depends on the number of teeth it currently has vs the new size (and presumably the size and pitch of the chain).
blurredman
PostPosted: 14:40 - 24 Jun 2024    Post subject: Reply with quote
Front sprocket is cheaper too Laughing
Easy-X
PostPosted: 15:15 - 24 Jun 2024    Post subject: Reply with quote
For reference the 401 is 15T front, 45T rear, 520 chain, 112 links.
I'll give a 14T a go. The downside is 14T and smaller don't have the rubber noise dampening ring thingy. Probably due to the locking nut screw holes.
The last post was made 2 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 41.2 Kb
