| Belanir |
 Belanir L Plate Warrior
 Posted: 20:42 - 04 Jul 2024 Post subject: Brake Pad Too Tight? Sound is disturbing on new Tracer 9 GT+ |
Hello, I bought a Yamaha Tracer 9 Gt+ 2 weeks ago. When I bought it, I thought the brake pad was too tight. The dealer said it was like that because it was new. After using 800 km. the same situation continued in the first maintenance, again I was told that it was normal. However, I was not satisfied with it. Today, I did not use the rear brake at a distance of 6 km, but when I stopped, the rear disc was very hot. I am curious about your opinions, I am in a small city in Turkey and not many motorbike users around me. In the 25 sec video you can see the brake pad and sound. Video taken immediately after cleaning with brake cleaner spray
https://www.youtube.com/shorts/wvp2rABuNiU |
| Nobby the Bastard |
| Belanir |
| Easy-X |
 Easy-X Super Spammer
| stinkwheel |
 Posted: 00:36 - 05 Jul 2024 Post subject: |
Does it look to anyone else like there's an awful lot of piston showing for a brake with brand new pads on? Also that the calliper looks like it's fully against the stop on the sliding pins? So the static pad is jammed against the disc and the calliper can't float to the left any further. Like the whole calliper bracket should be sitting further to the left by 3 or 4mm OR the wheel/disc should be to the right by the same amount?
May be the angle of the video but I can't see the steel shim on the static pad (the one on the left). There should be a stainless steel shim with a fibre pad under it on the static pad exactly the same as the one you can see on the sliding pad. Has this been missed off because they couldn't fit the calliper on with it in there?
It's all a bit fuzzy on the video but is the back wheel in right? Looks a bit like there's a gap between the spacer and the wheel hub and the threads on the wheel spindle don't seem to be going all the way to the end of the nylok wheel nut.
I wonder if it's been assembled correctly? Maybe a wheel spacer in the wrong place or missing or a wheel bearing not seated correctly making the whole wheel sit further to the left than it should be? Is the wheel nut done up tight? Is there any side-to-side play (at all) on the rear wheel if the calliper is removed? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jaffa90 |
 jaffa90 World Chat Champion
| sickpup |
 sickpup Old Timer
| Easy-X |
 Posted: 09:34 - 05 Jul 2024 Post subject: |
What if the seal's round?  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| RhynoCZ |
 RhynoCZ Super Spammer
| stinkwheel |
| WD Forte |
 WD Forte World Chat Champion
| WD Forte |
 Posted: 14:44 - 05 Jul 2024 Post subject: |
Out of curiosity I tried to find a high res pic of the Tracer 9 GT rear brake
and only found one iffy pic I had feck aboot with
Our Turkish friends bike
https://i.postimg.cc/HkRz3WnF/tracer1.jpg
A Tracer 9 GT pic from the internet, possibly an earlier model
but the caliper looks 'right' to me
https://i.postimg.cc/25WwtpBy/tracer2.jpg ____________________ bikers smell of wee |
| RhynoCZ |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| Nobby the Bastard |
| Fizzer Thou |
| RhynoCZ |
 Posted: 20:57 - 13 Jul 2024 Post subject: |
Just for the fun of it, today I tried how freely my wheels spin. Not bad, I'd say.
I usually get to 4.5L per 100 km (62.77 MPG?) but also can do 4L per 100 km (70.62 MPG?) when I'm reasonable with the throttle and know the road well enough, so there's no unnecessary braking. Meaning, if there is any drag in the brakes, it's negligible.
*'87 Honda XBR 500
Both brakes have almost brand-new pads/shoes and the front caliper was fully rebuilt last year (fresh seals, brand-new pots, fresh DOT4). With a big single cylinder 4 stroke you don't use the brakes that much. Closing the throttle is often enough to slow down in front of most of the corners, almost like driving an EV with recuperation without the energy regen thing.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
The last post was made 2 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
