Charging System problem
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2
Lone-Wolf
PostPosted: 23:50 - 08 Jul 2024    Post subject: Reply with quote
Nobby the Bastard wrote:
So, what flavour of electricity comes out of the only to wires coming out of your alternator on you bike, AC or DC?
Wotcha.
It's an alternator - by the very fact that it's an alternator, AC comes out of it. The clue is in the name ALTernator - hence, alternating current. AC.
If it was a three phase alternator, then three wires would come out of it, and the output would be AC.
The two wires coming from a dynamo would be DC . + and -
Cheers.
L.W. - www.moonshiners.org.uk
Nobby the Bastard
Harley Gaydar
PostPosted: 07:37 - 09 Jul 2024    Post subject: Reply with quote
My point being is that yer typical alternator on yer typical motor vehicle has a built in reg/rec and so only has two wires for output and it's regulated DC so you don't have a seperate alternator and regulator.
Its a bit different if it has a stator built bolted onto the casing on the end of the crank.
Triumph Sprint ST 1050
Lone-Wolf
PostPosted: 12:01 - 09 Jul 2024    Post subject: Reply with quote
Wotcha.
My bikes are all old enough to have separate alternators. Prior to fitting modern regulator/rectifiers, they relied on a Zener diode and separate rectifier.
The alternator on my Ford trike has got the regulator/rectifier built in, and that has only the one output wire coming from it.
Cheers.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:46 - 09 Jul 2024    Post subject: Reply with quote
What sort of output does the alternator on the most modern of your vehhicles have? DC?
LatencyXR
PostPosted: 00:21 - 10 Jul 2024    Post subject: Reply with quote
Bikes now fixed, thanks for the advice.
Regulator replaced.
Honda CB300R - More 125's then the heart can handle!
The last post was made 1 year, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 44.83 Kb
