ATF Fluid as chain lube
flyingcbf
PostPosted: 10:38 - 05 Jul 2024    Post subject: ATF Fluid as chain lube Reply with quote
Hi Folks,
I have a 5L can of Automatic Transmission Fluid in the shed, sealed. But sitting for many years and never used or opened. Can I use this to lube my motorcycle chain? I can;t see it doing any harm?
I don't intend to use on any vehicle and don't really wanna chuck it away. Would like to make use of it somehow.
I have been using Gear oil, I believe 80W stuff but have now run out. But before I go and spend money on another gear oil, can I just use this on the chain say every 200 miles? Confused
2019 Suzuki V-Strom 250
2020 Cb125F @ 5k miles and going up!
PostPosted: 11:09 - 05 Jul 2024    Post subject: Reply with quote
You can use ATF, it's thinner than chain lube so will fling off making more of a mess, you'll need to be careful not to apply too much and you'll have to reapply it more frequently.
RhynoCZ
Well, you can but I wouldn't. ATF is very thin and does not stick to surfaces... in other words you'll be spraying the oil all over the street and your clothes/bike gear while riding.
PostPosted: 13:06 - 05 Jul 2024    Post subject: Reply with quote
You can use it as fork oil, it's around 5wt. Most Hondas of the 90s' actually specify ATF in the forks.
It also makes a really good penetrating fluid for stuck/rusted fasteners. Dilute 50:50 with acetone. Substitute paraffin for acetone if it's going to go near any plastic or rubber componants.
As above, it will lube your chain but will also make an unholy mess.
flyingcbf
PostPosted: 14:14 - 05 Jul 2024    Post subject: Reply with quote
OK, thank you for your replies. Gear oil isn't expensive so I'll buy some more. 90w stuff.
As for the ATF, I'll mix this stuff with old engine oil and paint the fences in the garden Very Happy Thumbs Up
RhynoCZ
PostPosted: 18:34 - 05 Jul 2024    Post subject: Reply with quote
Yes, that as well. I use ATF in the forks of my XBR 500, as in accordance with the service manual. ATF is also used in 80's and 90's German cars as the power steering fluid.
flyingcbf
PostPosted: 16:02 - 12 Jul 2024    Post subject: Reply with quote
So I've gone ahead and ordered the folowing...
https://lh3.googleusercontent.com/pw/AP1GczMfXi69hTC91lCyznJZ2KJVt9uYnZPeSuKovO2o0Pi8SWDCTG82PM0XIl1Y7IdcWl9D-qyEhEKP5C8FUjn2Gba83q1E-MhJ-zS9B2XylrRUKN0Dfq3E-WBKyeb9yJdCDiO2A6Gu-kNEDju_D7vdAuzp=w1004-h457-s-no-gm-no
PostPosted: 16:11 - 12 Jul 2024    Post subject: Reply with quote
What's wrong with using chain lube to lube the chain?
Evil Hans
PostPosted: 16:40 - 12 Jul 2024    Post subject: Reply with quote
I thought this was a question about using up stuff that was already in the shed?
If you need chain lube, buy chain lube and stop titting around.
Triumph Sprint ST 1050. And it's Red.
The last post was made 2 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 61.32 Kb
