| CraddyMcPatty |
 CraddyMcPatty Derestricted Danger
| jeffyjeff |
 jeffyjeff World Chat Champion
| CraddyMcPatty |
 Posted: 17:35 - 14 Jul 2024 Post subject: |
| jeffyjeff wrote: | Although similar, the XS125-K is not a clone of the YBR. Starter motor location is the most obvious difference. Also the SYM bikes in my Google search are carbureted and the YBRs post 2006 are fuel injected. Swapping out your engine for a YBR will not likely be "plug-and-play".
SYM (Taiwan) has a better reputation than mainland Chinese motorbikes, in my experience. If your bike was mine, I would undertake a serious diagnosis as to the cause of the vibration. The shaking over 4000RPM will not be solved by some bolt-on aftermarket part. Your motor likely has an internal balance weight (gear or chain driven) that is timed to the crankshaft and driven at twice crankshaft speed. If that balance weight was somehow misassembled or otherwise jumped time, that could cause your condition. However, your vibrations could also be caused by something as simple as a loose, cracked, or broken motor mount, or perhaps misalignment when the engine was fit into the frame. Worth checking into. |
Thank you for the insight, and considering my SYM was once wrecked in one way or another, then sold to me, something might very well be broken on the inside, although it runs fine, but doesn't run as smooth as a YBR 125 (The SYM vibrates A LOT more), and so I was wondering if maybe they SYM XS125-K just came without a dampener/balancer.
Also a friend of mine has an '08 YBR 125 w/ a carb so maybe try checking up on your info? But this is besides the point.
Appreciate the help, thank you. |
| jeffyjeff |
 Posted: 21:22 - 14 Jul 2024 Post subject: |
If it was wrecked before, that is even more suggestive that a cracked or broken motor mount could be the cause. Your problem might not be internal at all, and if not, should be easier to find and fix.  ____________________ History shows again and again how nature points out the folly of men - BOC |
| jeffyjeff |
| CraddyMcPatty |
| WD Forte |
 WD Forte World Chat Champion
| CraddyMcPatty |
The last post was made 2 years, 46 days ago. Instead of replying here, would creating a new thread be more useful? |
