| stinkwheel |
| Easy-X |
 Easy-X Super Spammer
| stinkwheel |
| Easy-X |
 Posted: 21:15 - 16 Jul 2024 Post subject: |
Well it doesn't look great given the symptom is intermittent spark but to be absolutely certain one would need to compare to a working system - easier said than done  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| A100man |
 A100man World Chat Champion
 Posted: 23:11 - 16 Jul 2024 Post subject: |
I'd expect it to be more consistent.
It's possible the sample rate of the scope is not high enough at that timebase and you're not seing a true representation, turn up the timebase so you can only see a couple of pulses and see if they become more even. Maybe try 'single shot' mode. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| WD Forte |
 WD Forte World Chat Champion
| WD Forte |
| stinkwheel |
 Posted: 19:27 - 17 Jul 2024 Post subject: |
Cool, I have stuff to check. It was working before but the charging coils on the stator went thermonuclear, probably due to it constantly dumping because of having zero load on it. I've resigned myself to it probably needing a battery and I replaced the stator coils with a more basic AC/DC setup in a C90 style (yellow, white and earth) but will never use the AC side, so like riding a C90 during the day.
It took out the ignition source coil too (lucky there wasn't a fire really). Stator comes with one fitted and while the pulse coil looks identical, I have suspicions about it maybe being a bit out of kilter either with signal or clearance. I'll get the whole lot up on the lift. It's just hard to reach. I can look at the pulse coil but only with the stator coils removed from the back plate. Now I have a scope, I suppose I can just remove them for a bit and tune in the pulse coil., then worry about the rest of it. I think the old one is actually ok so I can compare that too.
I turned down the timebase as suggested by A100man. Looks like it's pulsing regularly, Perhaps just not a high enough waveform to trigger the spark? Only getting 0.3V. Ovalling out the the holes in the stator plate and dialling in the gap between the trigger and the pickup is probably the first step?
https://lh3.googleusercontent.com/pw/AP1GczO8W5hmTBsO_5_ECxv17KMD-a7UgAV9mJOyhnni4CkRJ2QNk7v6FZQxIGwOKh4pNugfzrk9zfMRdz3QslA6ipdI3nyNAAvPgfOlPm9jUrdtSsQ_3Qs2QHEZDgqwjZeyPJFV2irDwtHXcgVC89SQKPps=w1557-h876-s-no ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
| WD Forte |
| stinkwheel |
 Posted: 21:33 - 17 Jul 2024 Post subject: |
Oh, I think the noise on the signal may be the mains powered electric drill I was using to turn the engine.
It's good I found this anyway, this will almost certainly be why I have intermitant sparking.
I should be able to make it work with this setup. The bike's done over 500 miles without a glitch on the ignition side. It's got to be either a misaligned/mis-gapped sensor or a dodgy sensor.
I just didn't want to have to take all this stuff apart again but I'm going to have to. I effectively just want the pickup coil and bare stator plate and need to keep tinkering until I get a better signal.
Here's the pickup. As you can see, it's pretty tight for space in there, with the stator and rotor fitted, the space is pretty much full. I can't see any way I could mount a trigger on the rotor. Also, the rotor isn't keyed.
https://lh3.googleusercontent.com/pw/AP1GczNUpJ3GqFqYsGeY3GoeVvdh_roKmrZJlgerzs-GniT_XdaexUr5A6K4S3ct6j9agfmQ0dMnLowUb7SRsxyfHN34VBlsR-Aiwi48iW08_yckNBTgKFGykfImojj5LFaTcyD6jvKam3kV3lo1aHjGkdos=w1557-h876-s-no
I'll keep things updated. I'm enjoying playing with my new gadget anyway so that makes the faffery less annoying. It'll also be better when I get Mrs stinkwheels bike off the lift so i can work at eye level instead of grubbing about on the floor. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
| A100man |
 Posted: 22:14 - 18 Jul 2024 Post subject: |
some/most scope probes are x10 attenuating. It looks like your scope is set to x1. Perhaps worth checking what's written on teh probe or check against the 'Cal.' signal of the scope if it has one. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| stinkwheel |
| stinkwheel |
 Posted: 18:59 - 04 Aug 2024 Post subject: |
Update on this. I swapped out the pickup coil for the one off the burned out stator. Which is identical in every respect including clearances and coil resistance. It's giving the same profile spike but at 3.2V. It also now makes a spark. So the one I was testing was definately duff.
Goes to show that just because the resistance reading on a pickup coil is good, doesn't mean the coil itself is doing what it's supposed to ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| A100man |
 Posted: 13:38 - 05 Aug 2024 Post subject: |
Aye.. Resistance alone ain't a great test as I discovered on my failing XJ ignition coils that tested for resistance perfectly.
A new set has absolutely transformed the starting..
(see what I did there..) ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| lingeringstin... |
 lingeringstin... Spanner Monkey
| blurredman |
 blurredman World Chat Champion
 Posted: 08:51 - 06 Aug 2024 Post subject: |
| lingeringstink wrote: |
A CX500 was the only bike I ever had where changing the CDI meant dropping the whole engine out. Whose fucking daft idea was THAT? |
Surely the cdi part is on the frame. You're talking about the coils really. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| WD Forte |
| blurredman |
 Posted: 08:14 - 07 Aug 2024 Post subject: |
| WD Forte wrote: |
Yep, the CDI box is/was under the seat
The transverse engine meant you had to drop the lump to remove
the rear cover to change the stator or pulsers or cam chain.
Dropping the lump and changing the stator or cam chain was pretty easy once you had the correct tools to hand, did that load of times. |
Yes, I can get the engine out and the back cover off within the hour. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
The last post was made 2 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
