| ColinH |
 ColinH Derestricted Danger
 Posted: 07:21 - 19 Jul 2024 Post subject: |
Are you turning the output shaft as you try to shift it? Have you refitted the clutch?
Remember a gearbox won't always shift properly unless the bike is rolling and the clutch is disengaged. If you're trying to go through all the gears with the engine stationary on a bench, I wouldn't expect it to get them all all the time, just like if you stop in top gear and try to change to first, you need to rock the bike and fiddle with the clutch.
To answer your question, a lot of honda parts are marked with whole or partial part numbers. There have been a lot of differnt GC125s so you'll need to look yours up, an example of a CG selector fork part number is: 24211KPT900
If you go on CMS and find your model, they have parts lists which include an exploded diagram of the gearbox, part numbers and if you click on the part, usually a photograph of the part. Should be able to aork it out from there.
https://www.cmsnl.com/honda-cg125_model1192/ ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ColinH |
| WD Forte |
 WD Forte World Chat Champion
| ColinH |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 13:09 - 20 Jul 2024 Post subject: Re: Honda CG125 Gearbox |
| RhynoCZ wrote: |
Not sure about Honda, but some bikes do need a gasket of proper thickness between the two halves of the engine (gearbox) to function properly. |
A good point, vertically split gearboxes need the right amount of end-float to work properly, you may even be slightly bending the selector guide rods with no gasket in. Some are fussier than others, you have to shim the ends of the shafts on some older bikes, which is a faff (dismantle, reassemble with plastiguage, dismantle, reassemble with shims and hope you got it right). I suspect a CG is more forgiving and engineered with better tolerances. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ColinH |
| lingeringstin... |
 lingeringstin... Spanner Monkey
The last post was made 2 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
