| rego21 |
 rego21 Derestricted Danger
 Posted: 14:13 - 21 Jul 2024 Post subject: |
Old electromechanical indicator relays are sensitive to the load on the circuit. If the bulbs are the incorrect wattage, it will not flash correctly (or will flash too fast). If the voltage supply is incorrect, you can have similar issues.
I'd replace it with an electronic flasher relay anyway which will flash at the same speed regardless of what else is going on. It may be showing you have a charging issue or a dead/dying battery which would also be worth testing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| rego21 |
 Posted: 15:08 - 21 Jul 2024 Post subject: |
An earth problem is certainly something to investigate. I presume it's a 6v electrical system?
It might also be that the rectifier has failed and is putting out AC instead of DC or an excessive voltage. Is your 7-8v across the battery with the engine running?
EDIT: I think your bike is 12v so where is the 7-8V reading coming from? It's not right. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| rego21 |
| rego21 |
 Posted: 15:56 - 22 Jul 2024 Post subject: |
You aren't going to get stable and sufficient DC out of that charging system without a battery. It'll run the lights fine because they are on direct AC and as you correctly pointed out, the ignition self-excites.
You have no chance of it running the flashers/brake light/horn direct without a battery, a capacitor or a special reg/rec. Even then, they don't really generate enough power directly to light up the incandescants, they rely on the battery storing power and it being used intermittantly.
TL;DR. You need a battery. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| rego21 |
| jeffyjeff |
 jeffyjeff World Chat Champion
| rego21 |
| jeffyjeff |
 Posted: 19:39 - 22 Jul 2024 Post subject: |
I think the 1992 will be a Brazilian model which has two coils on the stator.
One of them provides power for the spark, this is a totally seperate system and has nothing to do with the lighting or accessories. So a running engine tells you nothing about the rest of the electrical system.
The other coil is split in half. When the lights are off, the two halves feed into a basic regulator rectifier which gives a very dirty 12V DC output to the battery. When the lights are on, one half of the coil feeds AC power directly to the lights. The other half feeds even dirtier and less power to the battery. Almost certainly not enough power to light up the brake light and indicators together.
It's a cheap and nasty charging system designed to store enough power in the battery to make the flashers and tail light work when they are needed. It's also basic and reliable if it's used as intended and the seperate ignition coil means it's unlikely to leave you stranded at the side of the road with no spark, even if all the rest of the electrics fail.
I've been trying to make a similar but slightly more refined system work without a battery on my current project bike, I've been using capacitors to do the job of the battery. I haven't been able to get it to work reliably and it's cooked two stators so far. Attempt three is going to be me giving up on the idea and fitting a battery.
I also have two dead flasher relays. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| rego21 |
 Posted: 21:53 - 22 Jul 2024 Post subject: |
| stinkwheel wrote: | I think the 1992 will be a Brazilian model which has two coils on the stator.
I also have two dead flasher relays. |
You are absolutely right, its a 1992 Honda Brazilian model!
Wow dindt know about that, thanks for the info! What doesn't make much sense on my case, its why the indicators and brake light works without a battery. I believe they should need one to operate, but from the kickstarter they work...
My idea was and still is to use a capacitor instead of the battery, however since I couldn`t go for a ride yet I wasn't able to test the solution properly... What issue have you found so far with the capacitor solution ?
Thanks again! |
 Posted: 23:18 - 22 Jul 2024 Post subject: |
| rego21 wrote: | What issue have you found so far with the capacitor solution ?
I was still getting a fluctuating power supply, despite using several different combinations of capacitor to try to smooth it out. Probably less of an issue with incandescant bulbs but I'm using LEDs on this build and it caused an unacceptable amount of flicker.
The battery also acts as a power sink. Without it, the excess is just dumped to earth by the regulator, this was leading to the stator overheating, then eventually shorting when the insulation broke down and burning out.
I have an oscilloscope now which would probably help with stabilising the output so I would be able to dial out the flicker with a bit of prototyping using different value capacitors but it wont help with the overheating. I'm just going to use a small battery, it's simple and will just work.
Mine is wired for DC only. With hindsight, if I was doing it all again, I'd use an innova 125 reg/rec and copy their system which uses a single coil and passes half the waveform for positive earth, voltage regulated direct lighting and the other half for negative earth charging. It would probably still need a battery to get a clean DC output though. It's a clever system and effectively gets you double the useable power from the same size coil. I'm not going to post a how-to about it though, if you can look at the wiring diagram and understand what's going on, it's something you could think about. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| rego21 |
 Posted: 23:27 - 23 Jul 2024 Post subject: |
| stinkwheel wrote: | | rego21 wrote: | What issue have you found so far with the capacitor solution ?
Mine is wired for DC only. With hindsight, if I was doing it all again, I'd use an innova 125 reg/rec and copy their system which uses a single coil and passes half the waveform for positive earth, voltage regulated direct lighting and the other half for negative earth charging. It would probably still need a battery to get a clean DC output though. It's a clever system and effectively gets you double the useable power from the same size coil. I'm not going to post a how-to about it though, if you can look at the wiring diagram and understand what's going on, it's something you could think about. |
Thanks for the great input! Having this feedback I believe I will abandon the capacitor idea and just use a battery instead. |
| rego21 |
| rego21 |
 Posted: 18:48 - 24 Jul 2024 Post subject: |
Thanks again! But, how should this be related to the fact that the indicators, brake light and horn are working when I don't have a battery connected ? |
 Posted: 20:07 - 24 Jul 2024 Post subject: |
| rego21 wrote: |
It'll be running off that power directly from the reg/rec as the bike generates it, that's what usually charges the battery. Just, as you can see, it's not a very constant voltage and the frequency of the peaks is dependant on the rev speed (what I referred to earlier to as "dirty" power). That's what your bulbs are seeing. It'll light up an incandescent bulb reasonably well because by the time the filament has started cooling down in the gap, it'll be heating up again from the next peak (although I'd query if they are reaching full brightness due to the overall feebleness of the output). It could well be upsetting the flasher relay, especially an electronic one.
With a battery (or the right combination of capacitors), those gaps in the output will be filled in by the power stored in the battery and you'd have a more or less constant flat line 12VDC for the voltage output. Which electronics will thank you for. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| rego21 |
 Posted: 23:01 - 24 Jul 2024 Post subject: |
With a battery (or the right combination of capacitors), those gaps in the output will be filled in by the power stored in the battery and you'd have a more or less constant flat line 12VDC for the voltage output. Which electronics will thank you for. |
Thanks again, you are great!
So if I understood correctly:
The stator will produce AC that will feed the reg/rec. Then, it will convert to DC and power all the components (I think this was the part I was missing, I was thinking that it would only power the front and back light). Since this DC voltage its unstable it may damage the relay and make it unusable. So without battery what I get is:
Front and back light working
Brake light working
Horn working (probably by pressing the horn I will notice this insatiability of the DC voltage)
Indicators working but stall since the relay is fried
Am I correct ? |
 Posted: 07:36 - 25 Jul 2024 Post subject: |
That's right, except the head and tail light are running on AC directly from the stator on a seperate set of wiring and so only work when the engine is running even if you do have a battery. So what you have now is how it's set up to be.
Only the flashers, brake light, horn and warning lights work from the DC side. I'd imagine you probably need to rev it quite hard to make the horn sound like anything other than a strangled duck with no battery which shows how little output there is. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| rego21 |
| Easy-X |
 Easy-X Super Spammer
| rego21 |
The last post was made 2 years, 36 days ago. Instead of replying here, would creating a new thread be more useful? |
