Calling adhesive gurus...?
Freddyfruitba...
PostPosted: 19:33 - 04 Aug 2024    Post subject: Calling adhesive gurus...? Reply with quote
I recently had a low-speed off on my BMW boxer twin, and fortunately my cylinder head protector did exactly what it was supposed to. However in doing so, an aluminium plate came unstuck from the main plastic body:
https://www.wunderlich.de/thumbnail/cf/23/9e/1722566107/35613-002_web_blank_03.jpg_400x400.jpg
I'm probably overthinking it, but bearing in mind the adverse conditions (mechanical strength/ high temperature etc) I emailed the German manufacturer and asked what type of adhesive they use, and was advised it was the following, a 'single component polyurethane':
https://eshop.wurth.co.uk/Product-categories/Bond-and-Seal-structural-adhesive/31083005041106.cyid/3108.cgid/en/GB/GBP/
Now I can obtain exactly this stuff in the UK for sure, but it's no doubt going to be highly expensive, and truth be told, I've probably already got an equivalent in my glue collection here anyway. Would anyone who knows about this stuff be able to advise the specifics of what I should be looking for?
Nobby the Bastard
Harley Gaydar
PostPosted: 19:42 - 04 Aug 2024    Post subject: Reply with quote
https://www.screwfix.com/p/gorilla-glue-polyurethane-adhesive-250ml/51887?tc=CB5&gad_source=1
Triumph Sprint ST 1050
PostPosted: 20:01 - 04 Aug 2024    Post subject: Reply with quote
https://industry.sika.com/en/home/appliance-and-equipment/hvac/sikaflex-221.html
https://i.imgur.com/9DuLVSy.jpg
Rain
PostPosted: 20:49 - 04 Aug 2024    Post subject: Reply with quote
I would use something like this https://www.firestoppingshop.com/product/safire-high-temperature-adhesive?gs=1&gad_source=1&gclid=Cj0KCQjwzby1BhCQARIsAJ_0t5Oo-0FEnwNzVeLmzaBt0SexTb2Q3vH-L3_IBb3oMMggDio1yIZWqe8aAlvjEALw_wcB
However if you dont need the temperature Sikaflex is brilliant stuff, Use it on my boats all the time. There are some really fancy ones but this is my basic go to choice.
https://www.amazon.co.uk/Sikaflex-permanently-recoatable-properties-homemobiles/dp/B0C1HHGNMJ/ref=sr_1_6?dib=eyJ2IjoiMSJ9.JHPJP2t5uXywlqsS9G2vEzYkQmn_k3vHbHZUOEYVBrG3LVrpaqRCo_vEaPXRzAMJb3Tao8R8y-5914R1LXtCqYI3TDlgxrzQRPz3I1aAuC8pBIMSNsnDP7UF54UlSFbH6Uz9oeeM-
Edited to add, Ste beat me to this one but Sikaflex s epic stuff, Up with Loctite as a brand in my view.
PostPosted: 20:51 - 04 Aug 2024    Post subject: Reply with quote
Remember there are foaming and non-foaming polyurethane adhesives. If there is a slight gap and you can clamp the pieces firmly together as it cures, the foaming sort is better because it'll get a bigger surface area and fill any gaps. Squeeze-out is easily trimmed with a sharp knife once it's cured. If you can't clamp it firmly, the foaming will push the pieces apart slightly.
As above, gorilla original is a foaming polyurethane. Gorilla crystal clear is non-foaming.
I use West Systems G-flex epoxy for most adhesive jobs and it's what I'd use there. You need to briefly run a blue gas flame over the ABS just before you apply the adhesive then tape it down hard while it cures.
Or thin 3M VHB sticky pads?
Fat Angry Scotsman
PostPosted: 12:07 - 05 Aug 2024    Post subject: Re: Calling adhesive gurus...? Reply with quote
I would get normal epoxy mix that shit up and paste it on to the back of the aluminium using a sacrificial paint brush across the whole surface then stick it on and pay my kid £5 to sit and watch youtube for an hour on his ipad while holding it in place Laughing
Freddyfruitba...
PostPosted: 12:53 - 05 Aug 2024    Post subject: Reply with quote
Thank's a lot, all - much helpful info here.
Ok, that's news to me. How would you know/tell which type you have? Can't see any mention of this on any of the links provided in this thread
PostPosted: 15:49 - 05 Aug 2024    Post subject: Reply with quote
I generally consider any polyurethane adhesive to foam to some degree unless it specifically says it doesn't (eg, gorilla clear).
Foaming is a good thing, it makes the join stronger and more flexible. It does however need to be clamped/taped down while it cures.
lingeringstin...
PostPosted: 23:23 - 05 Aug 2024    Post subject: Reply with quote
I haven't found any glue better than Serious Glue for gluing random shit together. It's not that easy to find, slightly expensive, and when you do open a tube it will probably go hard before you need to use it again but it's the best glue I have ever used.
The last post was made 2 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.14 - MySQL Queries: 13 - Page Size: 64.87 Kb
