Ducati diavel oil light on
 Topic moved: from Forum Feedback & Help to The Workshop by stinkwheel (12 Aug 2024 - 16:01)
March1
PostPosted: 14:32 - 12 Aug 2024    Post subject: Ducati diavel oil light on Reply with quote
Had my bike serviced new oil , oil levels all good but light on any ideas how Fix this issue please
Mh12
doggone
PostPosted: 15:38 - 12 Aug 2024    Post subject: Reply with quote
I suppose it might need diagnostic box to turn it off if it briefly thought no oil pressure when it was first started.
This is not normally required. It might go off itself after a few restarts.
PostPosted: 16:01 - 12 Aug 2024    Post subject: Reply with quote
Thing is, it might be right so I wouldn't be running the engine with an oil light on until I'd checked.
They usually measure oil pressure, not oil level on most (but not all) motorbikes which is why it comes on with the ignition then goes off after starting. Does it have a sight glass? Look in that and press the starter, the oil level should drop within a few seconds if the pump's picking it up.
WD Forte
PostPosted: 21:19 - 12 Aug 2024    Post subject: Reply with quote
+1 check you have oil pressure or its fooked
If you're lucky, the oil light doubles as something else,
a bloody stupid idea but you never know.
I do recall some guys US spec bike had the oil light double up as
a bulb failure indicator which caused a few stained underpants until
it was realised.
Edit:
read this thread
https://www.diavel-forum.com/threads/pressure-sensor-light-comes-on.79002/
bikers smell of wee
The last post was made 2 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 1.16 - MySQL Queries: 16 - Page Size: 39.65 Kb
