| OhHowOriginal |
 OhHowOriginal Two Stroke Sniffer
| Nobby the Bastard |
| Kawasaki Jimbo |
| OhHowOriginal |
| Nobby the Bastard |
| OhHowOriginal |
| OhHowOriginal |
| Nobby the Bastard |
| OhHowOriginal |
 Posted: 20:00 - 15 Aug 2024 Post subject: |
Looking at parts lists, it's a single pickup ignition with three triggers on the rotor, one at TDC, one about 20 degrees or so round from it with the timing mark near it and a third at around 90 degrees so it may not be a straightforward wasted spark.
EDIT: No scrub that, it's a wasted spark, just checked a wiring diagram. Swapping the plug caps on 2 and 3 should make no difference on a normally functioning bike. Your problem is electrical. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| OhHowOriginal |
 Posted: 22:26 - 15 Aug 2024 Post subject: |
One of the coils does 1 and 4, the other coil does 2 and 3.
Each coil has a 12v supply in a black on red wire from the kill switch/safety interlock box. Since you are getting sparks on one, this could only be a problem where it splits between the two coils or connects to them. Check for overall condition and make sure there's 12V in both when the ignition is on.
Each coil has a single wire running to the CDI, one orange and one grey. Worth having a good look at the one that's supplying the suspect coil at each end checking for corrosion on the connectors and maybe doing a continuity and resistance test on that wire.
It's a fairly safe assumption that everything upstream of the CDI is ok based on it only having one pickup coil and it producing a spark. I say fairly safe because weird things can happen but it would need to be something oddball like a partial failure in the CDI or a damaged trigger bump on the rotor. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jaffa90 |
 jaffa90 World Chat Champion
| that_impulse_guy |
 that_impulse_guy Scooby Slapper
 Posted: 08:12 - 16 Aug 2024 Post subject: |
going on from what stinkwheel said...if youre into diagnosis....the two wires going to the coil will be
1) one is permanently hot. 12v or thereabouts, when ignition is on.... Depending on bike and age of bike, this path may well go from battery, through ignition, through killswitch, to cdi..then from cdi to hot side of coil. ...any one of those items may well reduce the expected battery voltage (lets say 12.8v on a fresh battery), down by 1v or more...reducing spark power
2) second wire is ground, but not just any ground...its ground direct from the cdi...the cdi triggers this ground momentarily which causes the spark..
normally, cyl1+4 are together and fire at the same time, because its just one ground form the cdi to that coil thats getting momentarily interrupted by the cdi.
and then cyl2+3 is the other ground thats getting twiddled.
therefor, its totally possible to have the bike switched off, remove normal input wires from a coil.....run a 12v feed and a ground to the coil and manually twiddle the ground on and off to check for spark....effectively removing a lot of stuffs thats ordinarily in the way of getting a good spark.
and then you can work backwards from there...
before doing all of this, i tend to have the bike on but not idling or anything, just battery on, measure battery voltage, measure coil voltage, and then from there decide what Im gonna do..if theyre close, no need for the above tests...if theyre not close....then dive in. ____________________ Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R
| OhHowOriginal |
| OhHowOriginal |
| Easy-X |
 Easy-X Super Spammer
| A100man |
 A100man World Chat Champion
 Posted: 07:28 - 17 Aug 2024 Post subject: |
| OhHowOriginal wrote: | Update, so I've test all 4 sparks from all 4 HT leads, they're all strong and equal, I've changed the coil for cyl2 and 3 and it's sparking great now.
I put quite a lot of fuel down the barrel (out of frustration if I'm honest) and all 4 cylinders ran for a few seconds then cylinder 3 stopped again, so I did it again and the same thing... I'm thinking it's carb related, despite having had them off... Should I have them off again or is there somewhere else fuel could be getting stuck to just 1 cylinder?
Again, I really appreciate everyone's replies.
On another small note, I've just tried to tax the bike ready for MOT and it says I can't tax it without an MOT, so am I legal to ride it to the garage for an MOT and should it still pass on 3 cylinders? |
If you have some carb cleaner ( or 'Start ya bastard') with the airbox off you can squirt some down the mouth of #3 to see if that bring it on line = carb issue.
Can you drain the bowl of #3 to see if there's any fuel in it? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| OhHowOriginal |
| Kawasaki Jimbo |
 Posted: 10:02 - 17 Aug 2024 Post subject: |
| OhHowOriginal |
| A100man |
 Posted: 07:17 - 18 Aug 2024 Post subject: |
Can you run it in the dark to check for arcing on #3 ignition leads/cap?
I guess you might have to set-up a remote fuel tank. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| OhHowOriginal |
| OhHowOriginal |
The last post was made 2 years, 91 days ago. Instead of replying here, would creating a new thread be more useful? |
