| garacs |
 garacs Borekit Bruiser
 Posted: 19:09 - 03 Jul 2024 Post subject: |
So I made a small video of the engine starting when already hot. Cold, it needed the choke...
Here's the link
https://youtu.be/_kO2IB55lcg?si=hS3BcNRmwZSaimAY
The response to the gas is so slow I can take a coffee before it gets back to idle ...
Is this a definite sign that I need to reclean the carbs? ____________________ Working on it: Kawasaki Zephyr 550B 1991 |
| Nobby the Bastard |
| Robby |
 Robby Dirty Old Man
| garacs |
| garacs |
| garacs |
| garacs |
 Posted: 21:22 - 07 Jul 2024 Post subject: |
So I reinstalled the carbs, started the motor: only cylinders 2 and 4 were working... Which is weird, since it means both coils were not working properly. Switching them, now I had cylinder 1 not working again, all other cylinders working...
So I took out the coils and checked again with a multimeter the coils, the wires, the plugs. All specs within range. I cut the tip on both ends of all the coil wires to give fresh metal for the plugs to bite into.
I then replaced all the sparkplugs, with the ones the bike had when I bought it: now the engine started with all 4 cylinders!
But... since i was doing everything without the fuel tank attached (using the fuel inside the carbs bowls) I had to turn off the motor. When I restarted it, cylinder 3 was not working anymore....
Removed the carbs, cleaned again all jets (they were not clogged, but just in case and before you guys tell me to clean them anyway...) reinstalled all but no joy...
The engine starts even without choke (finally) but only on 3 cylinders.
If there is an air leak, I have no idea where it could be. Ah in the meantime I fitted new copper gaskets on the exhaust manifolds.
I am honestly thinking to replace the coils, wires and plugs... ____________________ Working on it: Kawasaki Zephyr 550B 1991 |
| A100man |
 A100man World Chat Champion
 Posted: 11:39 - 09 Jul 2024 Post subject: |
| garacs wrote: | So I reinstalled the carbs, started the motor: only cylinders 2 and 4 were working... Which is weird, since it means both coils were not working properly. Switching them, now I had cylinder 1 not working again, all other cylinders working...
I am honestly thinking to replace the coils, wires and plugs... |
On my FZ750 I had an issue with the NGK long reach resistor plug cap. Interestingly these plug caps can be disassembled which I didn't initially realise so it was frst 'fixed' with a 'racing' cap type in red silicone.
Anyhow once home I dismantled the cap extracted the resistor cleaned up all the (corroded) gubbins and I was good to go again. Just in case these are the same caps you have. Also you don't need resistor plugs AND resistor caps.
NB No 1 plug cap was the culprit - from the sidestad lean maybe. Perhap syou also swapped your plug caps about when trimming back teh leads.. 1 =>3 ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| garacs |
 Posted: 21:38 - 10 Jul 2024 Post subject: |
| A100man wrote: | | garacs wrote: | So I reinstalled the carbs, started the motor: only cylinders 2 and 4 were working... Which is weird, since it means both coils were not working properly. Switching them, now I had cylinder 1 not working again, all other cylinders working...
NB No 1 plug cap was the culprit - from the sidestad lean maybe. Perhap syou also swapped your plug caps about when trimming back teh leads.. 1 =>3 |
Interesting, didn't know you could disassemble the spark plug caps... ____________________ Working on it: Kawasaki Zephyr 550B 1991 |
| A100man |
 Posted: 16:10 - 11 Jul 2024 Post subject: |
| garacs wrote: | | A100man wrote: |
Interesting, didn't know you could disassemble the spark plug caps... |
Not all of them.. maybe not yours.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| WD Forte |
 WD Forte World Chat Champion
| garacs |
| garacs |
| garacs |
 Posted: 21:17 - 10 Aug 2024 Post subject: |
Here I am, back tinkering with my Zephyr after a small pause due to personal stuff getting in the way...
So I did not buy the coils as I was hoping to do. Yet today I brought it out again just to check... and it did not start.
I brought it back in removed the carbs, replaced the jets and gaskets with new ones I received in the meantime, and after a bath in ultrasonic, I reassembled everything back together.
Brought the bike out, pulled the choked and after some turns it started, but again, only runs with choke.
I also noticed now it was only running on cylinders 1 and 2.
So I did something you are not supposed to do... I unplugged the sparkplugs 3 and 4 with the engine running.
RPMs got higher so I "calmed" them down removing the choke, and the cylinders were happily running. As soon as I replugged the sparkplugs for cylinders 3 and 4 these also started to work, but really roughly and I had to adjust the idle a bit. Yet all 4 cylinders were working!!!
So I did the stpid thing, and shut the motor off... And restarting it, only ran on cylinders 1 and 2.
I unplugged them, and started the motor again, only having cylinders 3 and 4 plugged, and it ran only with choke.
So reassuming:
1 and 2 work without choke and with 2 and 4 unplugged.
3 and 4 work only with choke and 1 and 2 unplugged.
I swapped the coils around, same results.
Can someone let me know what the heck is happening???? ____________________ Working on it: Kawasaki Zephyr 550B 1991 |
| jaffa90 |
 jaffa90 World Chat Champion
| garacs |
| garacs |
| garacs |
| garacs |
| garacs |
| garacs |
| garacs |
| garacs |
| garacs |
| garacs |
The last post was made 2 years, 13 days ago. Instead of replying here, would creating a new thread be more useful? |
