how does a motorcycle regulate its charge
buddy
PostPosted: 15:14 - 20 Aug 2024    Post subject: how does a motorcycle regulate its charge Reply with quote
A car alternator does not use permanent magnets so it can whizz round and produce no voltage if required. A motorcycle uses permanent magnets, so how is charge regulated?
When this baby hits 88 miles per hour... you're gonna see some serious shit.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:42 - 20 Aug 2024    Post subject: Re: how does a motorcycle regulate its charge Reply with quote
It uses a regulator....
Triumph Sprint ST 1050
PostPosted: 17:30 - 20 Aug 2024    Post subject: Re: how does a motorcycle regulate its charge Reply with quote
Depends on the type but basically it either dumps electrical energy to ground (the chassis) and uses a heat sink to dissipate the energy or it open-circuits the alternator windings to remove the load.
struan80
PostPosted: 18:13 - 20 Aug 2024    Post subject: Reply with quote
Is it capacitor charge/discharge that keeps the induced stator output voltage even? Diode's change AC to DC which charges the battery and provides electrics when running.
This is my mad theory, without research. not based on any knowledge of anything motorbike like or my personal reality. Laughing I used to test Transformer rectifiers about 40 years ago. . Simpe IR and resistance measurement.
Robby
Dirty Old Man
PostPosted: 18:52 - 20 Aug 2024    Post subject: Reply with quote
Not as far as I know. It's 3 phase AC output being rectified to DC by 3 different diode pairs. You get a fairly stable voltage because it's 3 phase and has a battery. So no need for capacitors, the battery does that job.
blurredman
PostPosted: 08:09 - 21 Aug 2024    Post subject: Reply with quote
So many different answers can be given.
buddy
PostPosted: 15:33 - 21 Aug 2024    Post subject: Re: how does a motorcycle regulate its charge Reply with quote
Nice, does it open circuit the alternator at a high frequency like a switching power supply?
buddy
PostPosted: 15:34 - 21 Aug 2024    Post subject: Re: how does a motorcycle regulate its charge Reply with quote
what kind?
PostPosted: 21:05 - 21 Aug 2024    Post subject: Re: how does a motorcycle regulate its charge Reply with quote
what kind?
Usually either a zenner diode or a mosfet transistor circuit. Older ones tend to use the shunt type with a zenner. Newer/more expensive ones tend to use a mosfet.
There are some bikes that use a field coil alternator with a switched regulator, more like a car alternator but they are much less common. More common in European bikes but the odd Japanese one has them too, usually older models. I've had a few bikes where it was even an old-school electromechanical regulator.
The last post was made 2 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 64.24 Kb
