Blue spot front calipers, how to strip?
NJD
PostPosted: 15:17 - 22 Aug 2024    Post subject: Blue spot front calipers, how to strip? Reply with quote
The front brakes on my '99 FZS 600 are in need of a service and the local shop have showed their incomptience claiming the rear didn't need doing despite it turning the pads and disc blue so I'm going to attempt it myself (the fronts, for clarity.. I've done the rear).
Does anyone have a step by step guide? I know whilst the 'blue spot tool' is available to remove the 'blue spot' this is advised against because its pressurised?
One piston at a time? The piston removal tool might not be powerful enough (the one you put inside the piston and wriggle about) due to corrosion and I can't use my slide hammer kit because there's no space.
I'm just looking for the fastest and simplest way. I've done break rebuilds before, for clairty, its just I don't know if its a half a caliper at a time or one piston then bleed and then do another so on.. which would take forever.
I know the local shop used an air compressor last time but I don't have one. Unless there's one under £50 that's guranteed to work that I assume you stick down a pice of old brake hose attached to the caliper but off the bike?
redeem ouzzer
PostPosted: 15:40 - 22 Aug 2024    Post subject: Reply with quote
If you don't know how to do this then for all our sakes send the calipers to Powerline or someone who does.
Be a REAL MAN!
that_impulse_guy
PostPosted: 15:52 - 22 Aug 2024    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=285479
Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R
that_impulse_guy
PostPosted: 15:55 - 22 Aug 2024    Post subject: Reply with quote
just adding to my above post....my (not related to yamaha blue spots) front calipers are 4 pistons per side, I did them the old way...one clamp to hold one piston in, block of wood between the other two..and pump out last piston....clean...move on to next piston. Its not terrible to do if..
1) you have a spare master cylinder, in a vice (ebay sells a honda compatible part for like £11 all in with a lever etc)
2) you can then bleed the caliper very quickly to move on to the next piston because you can like, raise 'n lower it etc. Quick to do.
just..messy...lots of fluid...etc.
NJD
PostPosted: 17:39 - 22 Aug 2024    Post subject: Reply with quote
Right, because no one that has ever done a job on a previous bike has ever encountered the same job on a different one with a few added differences to work out before undertaking the task.
Many thanks for the non-helpful advice.
I feared this may be the case: slow and painful.
I don't have an extra M/C, do you have a link for that or roughly what I'd be looking for?
I assume you mean it would just be that £11 m/c into the caliper off of the bike and therefore would be easier to bleed because I wouldn't need to push the other side in and get all the air out after each piston on the caliper I was doing.
PostPosted: 18:58 - 22 Aug 2024    Post subject: Reply with quote
If you get exactly the right thickness piece of wood, and with cunning use of clamps if it seems to be going too far one way, you can usually pump all the pistons nearly all the way out using the master cylinder (you may need to top up the fluid). To the point where you can wiggle them the rest of the way out with your fingers.
It's how I did it last time I serviced my pretech 6-pots. I started by pumping them out against a reasonably thick piece of wood then went with progressively thinner bits (and finally a bit of alloy plate) until they were just hanging in there.
NJD
PostPosted: 19:25 - 22 Aug 2024    Post subject: Reply with quote
I was thinking that, but I know that there's two big pistons and two smaller ones (one of each per side) with the four pots, and I think that's by length too (marginally though, I believe). Suppose I could do a thin piece of wood and something either side and then use the pliers to get them out -- either that or the one by one method seem my best choice.
Probably see how easy they come out first. The piston pliers had no chance of removing the rear's given I'd left it so long since last rebuild and even with hydraulic fluid it took a while (which of course is the strongest method to get a siezed piston to move).
Guess I'm going to have fun Laughing Thumbs Up
struan80
PostPosted: 21:11 - 22 Aug 2024    Post subject: Reply with quote
Brakes only slow you down.
that_impulse_guy
PostPosted: 08:58 - 23 Aug 2024    Post subject: Reply with quote
https://www.ebay.co.uk/itm/365031940796?_nkw=honda+front+brake+master&itmmeta=01J5Z3V6KZ2N198HZS83ZG26D3&hash=item54fd9962bc:g:y9kAAOSw1SNmo27h&itmprp=enc%3AAQAJAAAA0HoV3kP08IDx%2BKZ9MfhVJKl3GgaQAIWFm4s5cVUYfPZMYTE3cnBxdrxpizmIAZzrl4nrmxidQhfwBO%2Bq6Zn5wTvDCKxLz%2BlsDl5D5b7Yjrc5IqjdAahEM3Lx7I01tlzuZchSyckqPb6%2FNPh5jpiOvxpFOQA23UpX8EFU7auPbnJCGhWSK8U3LE5XxXpVB4T6FouZNEp9XmQ8qsv63gBqr7rn0O%2BYLhdPuiJt2vr%2Fhf%2BdkNOAk3%2FX0hkU6tN4wx901PAUqD%2BhxvgMoAgZ4avhM7o%3D%7Ctkp%3ABk9SR5Dq7OOvZA
c_dug
PostPosted: 10:24 - 27 Aug 2024    Post subject: Reply with quote
Don't know where you're based but I am fairly certain I have a blue spot tool in my toolbox that you can have for free if you decide you need one, if you want it drop me a PM and we can sort out collection/postage.
andys675
PostPosted: 20:47 - 23 Nov 2024    Post subject: Reply with quote
I've go silver spots on mine off an XSR700
hardly worth servicing the blue spots, paid £60 for the first pair with oe pads still fitted about 4 years ago, came to service them a few weeks ago and managed to buy another pair on ebay for £40, again with near new oe pads
Fizzer Thou
PostPosted: 15:57 - 24 Nov 2024    Post subject: Reply with quote
I have done the calipers on countless bikes using the same method,be it on my blue spots or the YZF750R 6 pots.
https://i.postimg.cc/43QqrGGH/20200603-120409.jpg
By using an old master cylinder in a vice it was easy to do them on the workbench.You can also reuse the brake fluid once the pistons are out if you do not want to waste any.Bit messy but without a compressor it is the easiest.
https://i.postimg.cc/nhjXkVZs/IMG-20210821-WA0030.jpg
By holding one side of the caliper pistons at a time using one of these tools it was a lot easier.
https://www.ebay.co.uk/itm/395169591447?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D276749%26meid%3D39b3be9bffcc485993a2ef23ef333655%26pid%3D101875%26rk%3D1%26rkt%3D4%26sd%3D173980361917%26itm%3D395169591447%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DSimVIDwebV3WithCPCExpansionEmbeddingSearchQueryRecall%26brand%3DUnbranded&_trksid=p2332490.c101875.m1851&itmprp=cksum%3A39516959144739b3be9bffcc485993a2ef23ef333655%7Cenc%3AAQAJAAABQEK7FTfzsGw0VauxYyX1IOHjsuXJ1NPjVWebvOca%252BJbVzh3VqcrGnLFKHjKk2M42BtfNs8bK1jFneKBZqmubi3LtP5HaXYEMUaRbBzIO1kLDTmdjInf%252BO05bnZQ8kT0XHIya5K6VXYAi988tSW%252FPr%252FPcGjOKlKt4Aht85VlPA1GFU59DgadvkfaoXnsAyisiYtzUAJtFlVTIc9ZyDekImklebnUbjsoKfgfRmXbHESoqyZXsYAgnH5uMhyA5t9PMOQKDcuAM%252FggAadWp7yRAE9zeqAxCJy6r%252FKsWYTBK1DxqWOTk77whU5YL3eUi4t%252FaEZHqovw4BqdwvIIzyzO5DqrPHkzo6FoH9MDOE8MrVbq6JFPVh67xnEVeR7ue2GY7hFXFKUAoWYMw4itVLojS9iuwlDTHSf6Mdusn3kbNmH5Z%7Campid%3APL_CLK%7Cclp%3A2332490&itmmeta=01JDF9WP3EY6ARXSAYHGFSQE38
Always have a 'Plan B'
Nobby the Bastard
Harley Gaydar
PostPosted: 17:10 - 24 Nov 2024    Post subject: Reply with quote
I have a slide hammer kit...
Triumph Sprint ST 1050
Fizzer Thou
PostPosted: 14:16 - 26 Nov 2024    Post subject: Reply with quote
.....which will not work on monoblock calipers....
Nobby the Bastard
Harley Gaydar
PostPosted: 18:21 - 26 Nov 2024    Post subject: Reply with quote
Most monoblock callipers aren't 4 or 6 piston.
Fizzer Thou
PostPosted: 14:33 - 27 Nov 2024    Post subject: Reply with quote
Not sure where you get that idea from....
But all R1 front calipers are monobloc,be they four or six piston.This makes your tool unusable.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:31 - 27 Nov 2024    Post subject: Reply with quote
Is there another way they cann be removed without using air or fluid to pump them out seperately?
Fizzer Thou
PostPosted: 22:09 - 27 Nov 2024    Post subject: Reply with quote
Not ever tried one of these before so I do not know how successful it would be in removing stubborn pistons from a caliper
https://www.ebay.co.uk/itm/185908286958?_skw=brake+piston+removal+tool&itmmeta=01JDQQ4G1335Z4K4M7ZTNQ46XG&hash=item2b48ff55ee:g:RYQAAOSwZMNkatvL&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2BKZ9MfhVJKmMavHrj74t1NzFm3WXuc9Jz7heZK7JiC7R4%2FC6IhfEhQqenkVaj9meAuqj7cY5HsxFiFiHgVsak%2Bg91ylLld7cR6bh17%2BpvwMXLD7sc1cC3jxPLu7Jv6BGbC0gr4xihImI8XcOY1R%2FW3ey%2FaeZX1G7EqttmmKxjldDiksQPGRC0SXRSYDtBXJoCXV2pbN5ycc6c5g9odnJdGo3xkQNpMFvPkuRfsxcT3x%2BuR5S25D%2FQC0%2B94g0DpL1IiEGPFN7aekCbWbtFj9%2B90xHIQsHuV0%2FXpGkDzcfYtL89TTZL7tT9A%3D%3D%7Ctkp%3ABFBM0ICS9-1k
Nobby the Bastard
Harley Gaydar
PostPosted: 22:21 - 27 Nov 2024    Post subject: Reply with quote
Aren't they like blue spots where you can remove the back of the piston chamber and push them out?
Robby
Dirty Old Man
PostPosted: 10:23 - 29 Nov 2024    Post subject: Reply with quote
I have some of those pliers Fizzer Thou linked. They are fine for pulling out pistons from a decent caliper, useless for stuck ones. They will mar the internal surface, which is annoying.
Nothing comes close to hydraulic pressure for making things move that don't want to move. I have yet to come across a piston so rusted it can't be removed; I have removed a piston so rusted that the caliper got scratched to scrap in the process.
Something I haven't tried, but would be an interesting experiment, would be hooking up a stuck caliper to one of the corners on a car. A foot operated, vacuum boosted braking system will probably provide more pressure than my fingers on a handle.
Ducked
PostPosted: 02:19 - 30 Dec 2024    Post subject: Reply with quote
I have blown a one-pot caliper piston (Yamaha RZR) out by plugging the banjo bolt with the end of a chopstick having filled the caliper with ethanol, and then dropping it in boiling water and standing well clear.
Other volatile solvents (brake cleaner?) would probably work and probably shouldn't attack the rubber on the short residence time.
Described here
https://advrider.com/f/threads/your-favorite-macgyver-moments-tricks.387234/page-146#post-50310981
A multi-pot caliper would require more elaborate restraints and likely a phased, incremental approach so you get all the pistons to advance roughly together.
Allegedly you can also blow them out with a grease gun, but I havn't personally done that.
The last post was made 1 year, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.24 - MySQL Queries: 16 - Page Size: 122.14 Kb
