| Neon88Flex |
 Neon88Flex L Plate Warrior
| MarJay |
 MarJay But it's British!
| Neon88Flex |
| Kawasaki Jimbo |
 Posted: 19:31 - 29 Aug 2024 Post subject: |
K5 is a similar era to my ‘03 R1 so I’d say it’ll be nimble and flexible around town but slightly uncomfortable on wrists, hips, knees (I’m 61 you know!) for long periods in that environment. The R1 is a bit buzzy and sometimes vibey. Not sure about the Suzuki. I commute on it though. Looking over your shoulder for lifesavers is slightly more difficult when ‘tucked in’ compared to a more upright stance.
On the open road you might find yourself 50p-ing corners at first because it steers quickly and you’ll be tipping in too early. Power-wise, unless you’re cack-handed you take only as much as you need but you’ll notice the extra torque, meaning it’ll pull at lower revs/gears (although 900cc is already big, and gearing plays a part).
Posture and handling are probably going to be the biggest difference. Check out the two bikes on https://cycle-ergo.com/. Also the Suzuki is noteably lighter, I believe. |
| Polarbear |
 Polarbear Super Spammer
| UncleFester |
| The Tot |
 The Tot World Chat Champion
 Posted: 21:59 - 29 Aug 2024 Post subject: |
It's probably the most practical sportsbike you can imagine, from an era that produced balanced litre bikes. Given that the S1000RR was a faximile of the K5 is testament of the pedigree of that bike.
You'll have the characteristics of a well oiled Suzuki; slick gearbox and finely fettled fuel injection, but you'd have all the grumblings of any noughties thou such as cramped ergonomics, which are quite tolerable on the open road, but a ballache in town.
Having "1000cc" is advantageous in that you can be absolutely lazy with your gear changes. The roll on torque of that K5 motor with the gearing will mean that you can get away with leaving it in 6th for a roll-on overtake.
That being said, not IL4 engines are created equally. My Fazer 1000 has oodles of midrange and low down grunt, but my 4C8 R1 has a very peaky powerband that boots you once it hits 6k Rpm. The former is perfect for the road, whereas the latter will be better suited down the back straight at Snetterton.
Trust me when I say, you won't need any more power from that era litrebike. Dyno it by all means. The K5's power delivery is very linear for a thou.
Have a sit on one and convince yourself that you can filter one through traffic. If the answer is yes, then it's well worth a shout. Have you also considered a 954 FireBlade?
Both would be good contenders for roomy supersports, with good mannerisms for British roads. ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| MarJay |
| MyBi |
 MyBi L Plate Warrior
 Posted: 22:09 - 05 Oct 2024 Post subject: |
I've had a gsxr1000 k5 and was an awesome bike! I never had a single issue and I put 24k miles on it
Only maintenance I ever did was oil, and tires. Never even changed the plugs. And even after 24k and me absolutely abusing it! It didn't even burn oil.
Im more of a Honda guy myself and my cbr1000 burned some oil after 18k ____________________ ~ Motorized License Plate Flippers ツ ~ |
The last post was made 2 years, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
