3D printing
PostPosted: 22:43 - 02 Sep 2024    Post subject: 3D printing Reply with quote
I can't remember where i asked for reccomendations for a 3D printer but poeple said the ender 3v 3SE and I went with that.
Thanks to all who reccomended that, i've had such fun with it, I thught it would be tech heavy and all that but it isnt.
I can already see why I want a faster printer, 9 hours to print eldest grandson a triceratops but hey its great fun and evern technophobe proof.
panrider_uk
PostPosted: 22:45 - 02 Sep 2024    Post subject: Reply with quote
If you want faster you can get a resin printer quite cheaply now.
Fairly messy but using water washable resin they're not too bad
Much higher resolution prints too.
Easy-X
PostPosted: 10:34 - 03 Sep 2024    Post subject: Reply with quote
You can fiddle with the motor speeds, do some test prints to see how far you can push it. (Note that you might need to also tweak the head temperature at the same time.)
Also, check your infill settings. For something ornamental you don't need a lot of internal scaffolding to hold things together.
B1N
PostPosted: 18:28 - 05 Sep 2024    Post subject: Reply with quote
Once the print has started you can go into the 'Tune' menu and adjust the speed and other things while the printer is running, I've never messed with print speeds much, as print speed increases print quality decreases as a general rule.
This is a fun little print, you can make them in lots of different colours and just give them away to family and friends of any age, they can live on a desk, or a shelf or in a coat pocket.
https://www.thingiverse.com/thing:3495390
Cool
Ayrton
PostPosted: 15:49 - 06 Sep 2024    Post subject: Reply with quote
You can do stuff like decrease the infill to something really low if it's not something structural, or increase the layer height if you don't mind losing a little detail. Generally though things take a lot longer than you'd expect
Easy-X
PostPosted: 15:54 - 06 Sep 2024    Post subject: Reply with quote
Where appropriate you can also reduce the scale. The first major print I did was the Venus de Milo and the original would have just about reached the height limit of my printer. I rescaled to about two thirds the size, less material = quicker printing.
Islander
PostPosted: 13:15 - 07 Sep 2024    Post subject: Reply with quote
Resins need careful handling and decent ventilation as the resins used are pretty toxic.
If you haven't already done this, the next logical step with the Ender is to ditch the slicer software that they provide and upgrade to something like Ultimaker Cura (free to download and use).
It's a step change from the Ender slicer, is incredibly versatile and intuitive. It'll let you scale STL files as you slice and support management is a piece of piss too. It provides tree supports which use a lot less material and are easier to remove. Plenty of YouTube tutorials on it as well. Thumbs Up
PostPosted: 19:59 - 07 Sep 2024    Post subject: Reply with quote
I've been using both Cura and the Crealty slicer just comparing them.
I've had good prints with both. I have to agree though the Cura is a bit less heavy on the supports. The Crealty one could hold up the Empire state building with the size of the supports. I am only using what each slicer suggests though, I haven't worked out what I can remove and still have my print still standing at the end. Laughing
The last post was made 2 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 57.59 Kb
