Running lights (on cars)
PostPosted: 08:07 - 05 Sep 2024    Post subject: Running lights (on cars) Reply with quote
Just a question for anyone.
As obviously you are all aware, modern bikes lights turn on with the ignition. Headlamp and tail lights.
So why in god's name do modern cars with running lights only turn on the front and not the tail lights?
I ask because wifie has a habit of driving off to work in the twilight (illuminated street) with just the riding lights on. If the tail lights came on it wouldn't be so much of an issue but they don't.
Is there any logical or legal reason why they do not turn on withvthe running lights?
Robby
Dirty Old Man
PostPosted: 09:10 - 05 Sep 2024    Post subject: Reply with quote
I don't know why tail lights don't come on with running lights, but most modern cars have automatic headlights, where the headlights and tail lights come on when it gets dark (or you go into a tunnel, or under a particularly wide bridge).
So the problem is fixed on modern cars, but in a different way.
PostPosted: 09:53 - 05 Sep 2024    Post subject: Reply with quote
Hers doesn't, maybe because it's a Transit based model rather than a car? Ford Tourneo Connect 2016. Agreed though most other cars of that age will have auto lights.
doggone
PostPosted: 14:05 - 05 Sep 2024    Post subject: Reply with quote
That's another problem which explains why today about 1/3 of cars are driving about in pea soup fog off sea - not the borderline type misty fog - with no lights at all.
They probably don't know where the switch is.
Mind I have driven first mile or more with running lights on as they are pretty bright not much less than dipped beams.
blurredman
PostPosted: 15:02 - 05 Sep 2024    Post subject: Reply with quote
Running lights are a scurge.
The Artist
PostPosted: 16:47 - 05 Sep 2024    Post subject: Reply with quote
The rules governing daytime running lights are laid down in Regulation (EC) No 661/2009 of the European Parliament and of the Council of 13 July 2009, which refers to UNECE Regulation 48, which in turn is decisively influenced by the EU. According to the 05 series of amendments to the regulation (UNECE Regulation 48-05), rear lights on new private cars produced after 30 July 2016 must switch on automatically when it becomes dark.
As a result of this amendment, light sensors are to be fitted to all new models so that the rear DRLs are automatically switched on when it becomes dark. The reason why the rear lights, as opposed to the front lights, do not at present automatically switch on as soon as the car is started, is to do with CO2 emissions, which are reduced by rear lights being switched off when it is daylight.
I am pro being eco-friendly but I can't imagine the energy saving from not running rear DRL's all the time is much at all. Seems quite an odd choice. Some cars do have rear DRL's now though.
PostPosted: 16:57 - 05 Sep 2024    Post subject: Reply with quote
The Artist wrote:
b] The reason why the rear lights, as opposed to the front lights, do not at present automatically switch on as soon as the car is started, is to do with CO2 emissions, which are reduced by rear lights being switched off when it is daylight[/b].
That has to be the biggest load of horseshit I have read today. Laughing
virus
PostPosted: 17:14 - 05 Sep 2024    Post subject: Reply with quote
It reminds me of that top gear news segment where audi said they switched to energy saving leds from front DRLS and its half the drain of volvos system. May spoke to volvo to ask if they had calculated it and they said the drain was negligible but obviously audi just wanted to outdo the swedes Laughing
own: 81 xs1100g...
Easy-X
PostPosted: 17:19 - 05 Sep 2024    Post subject: Reply with quote
I'm in the middle of replacing the DRLs on the old Skoda at the moment (waiting on parts) not because of the energy savings but the heat. Over ten years of an always on filament bulb has partially melted one of the fittings. LEDs run much cooler.
Evil Hans
PostPosted: 15:54 - 06 Sep 2024    Post subject: Re: Running lights (on cars) Reply with quote
It's mental. I see this every evening driving home.
They stick the key in, weedy LEDS come on at the front, dash lights up, driver hits the road thinking his lights are on.
Makes no sense. Stupidest feature ever introduced.
PostPosted: 20:25 - 06 Sep 2024    Post subject: Re: Running lights (on cars) Reply with quote
I agree. Plus the dash lighting up all the time doesn't help. When it only illuminated when your lights came on it was obvious if they were on or off. I suppose modern dash boards are mailnly electronic display now though but they could have varying levels of brightness.
ThunderGuts
PostPosted: 11:07 - 13 Sep 2024    Post subject: Reply with quote
Some bikes do have DRL (I think the newer KTMs and BMWs?) although not sure if that illuminates the tail lights or not too.
The biggest issue I think are cars from the mid/late 2000s where it seemed to become common to have instrument clusters than illuminate but before the mandatory introduction of DRLs. Presumably the same category of drivers, except this time they've no lights at all but are blissfully unaware as they can see they're doing 40mph in a 30 limit.
Don't get me started on silver cars in daytime/twilight mist with no lights on . . .
TG.
The last post was made 2 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 76.97 Kb
