| Sulez |
 Sulez L Plate Warrior
| Easy-X |
 Easy-X Super Spammer
 Posted: 00:53 - 25 Sep 2024 Post subject: |
Let's quantify this situation, might be helpful...
Is this just in neutral or while riding? Does it idle okay? Whereabouts does it bog out? half-throttle, three quarters, etc.
You've bought new parts that didn't make a difference. Did you put the old parts back? (Sometimes you can make things worse by introducing new variables.)
Fuel, air and spark are the essentials. Throttle body and injector are the endpoints but is enough fuel coming out of the tank? Don't know this bike but it probably has a tiny fuel pump either inside or external to the tank, maybe that's the problem.
Have you checked the air filter and intake for blockages? Have you tried taking the air filter out to see if it's better or worse?
Finally spark. Always worth eyeballing the plug out of the bike to check the spark is bright and strong. After that I'm wondering if it's a timing issue as that would change as you go up the revs. Maybe a cam sensor fault?
Oh, and any engine warning light on this bike? ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Nobby the Bastard |
| WD Forte |
 WD Forte World Chat Champion
| Sulez |
| Sulez |
| Sulez |
| Sulez |
| Nobby the Bastard |
| WD Forte |
 Posted: 17:04 - 27 Sep 2024 Post subject: |
It probably does have a MAP sensor but like most small EFI singles
it's part of the throttle body assembly which has the TPS MAP and IAT
all in the same unit.
YBR's have this as did the Honda Forza I worked on/fixed recently
when I replaced what Honda called the above the sensor unit.
'hidden relay'? as in what they dont want you to know about?
it sounds as if you're playing swap and hope and making assumptions
Not best practise, test dont guess is a better method.
I'd start by opening checking and cleaning all electrical connectors and
ensuring the bike has good consistent grounding throughout.
EFI only uses a 5v supply to most sensors and the signal levels are even lower than this, so bad connections or grounding can easily give it conniptions. ____________________ bikers smell of wee |
| Sulez |
| Sulez |
 Posted: 21:11 - 27 Sep 2024 Post subject: |
| WD Forte wrote: | It probably does have a MAP sensor but like most small EFI singles
EFI only uses a 5v supply to most sensors and the signal levels are even lower than this, so bad connections or grounding can easily give it conniptions. |
If you google 2021 Herald mirage throttle body assembly you will see it does not have a MAP sensor at all it only has a tps sensor thats it. And some efi bikes do have hidden relays wrapped in the loom i had this issue on a similar bike. I have cleaned all the electrical connections today with contact cleaner and still no hope, i even took all the ground points off and sanded them. do you know how i can fix this problem thats showing on the code reader P0107 |
| WD Forte |
| Sulez |
| slowasyoulike |
 slowasyoulike Scooby Slapper
| WD Forte |
 Posted: 13:03 - 30 Sep 2024 Post subject: |
That video's got a god awful CG voice track
fuck that, I bailed 10 seconds in but did spot a pic of the combined IAT and IAP sensor on the inlet tube forward of the throttle body
The bike uses a Delphi ECU
probably an MT05
fault code P0107
"open circuit for intake pressure sensor
or
signal end pins shorted to battery negative"
This means its getting either a too high or too low a voltage
on the ECU's IAP pin
the ECU will expect to get voltages between say 1.5v and 3.5v
on this pin and anything out of bounds will trigger a fault
Its either bad connections or the sensor unit has failed
not magic hidden relays
https://imgur.com/vhp9rya.png ____________________ bikers smell of wee |
There is a gap of 265 days between these two posts... |
| AaronStan1 |
 AaronStan1 L Plate Warrior
The last post was made 1 year, 122 days ago. Instead of replying here, would creating a new thread be more useful? |
