FZ50 seat
my_quest
PostPosted: 15:56 - 03 Oct 2024    Post subject: FZ50 seat Reply with quote
I'm doing 1980 FZ50 X restoration...
The seat is in a bad state. The cover I can make/replace and the foam is still good.
But the metal formed/stamped plate is nearly completely rusted away.
I may be able to save it by cutting and welding new metal in place, but it won't be an easy job.
I was wondering if anybody knows if an alternate seat could be fitted?
Any thoughts appreciated.
slowasyoulike
PostPosted: 18:21 - 03 Oct 2024    Post subject: Reply with quote
Is there enough of it left for you to use as a mould for a fibreglass copy?
WD Forte
PostPosted: 18:31 - 03 Oct 2024    Post subject: Reply with quote
the FZ50 is the new flagship in Panasonic's big-zoom Lumix range, upping the image size to a class-leading 10.2 megapixels and adding a couple of welcome new features. Unlike the FZ30, which represented a leap forward in design and features over the FZ20 (and closed the gap between fixed lens and SLR cameras further than ever before), the new camera is a fairly minor upgrade. Then again, the FZ30 was hardly crying out for a massive overhaul; despite a wealth of 'super zoom' competitors it really does sit in a class of its own, offering true SLR-like handling and operation and an amazingly versatile 35-420mm equivalent 12x optical zoom (with fluid-damped mechanical zoom mechanism). So let's find out if the FZ50 is a worthy successor, and if it can overcome the few complaints we had, starting as usual with the headline features:
bikers smell of wee
my_quest
PostPosted: 11:48 - 05 Oct 2024    Post subject: Reply with quote
Yes, I think there is.
It's mostly rusted away around the edges, where the seat material has been turned under. I'm guessing it's where water has gotten trapped and rusted away the steel.
It's a good suggestion - so how do I make a mould?!
slowasyoulike
PostPosted: 22:21 - 09 Oct 2024    Post subject: Reply with quote
Make a brew and watch some videos... obviously for a seat base it's going to need to be sufficiently thick, but it is a workable solution; when the seat base on my Trail 90 rotted through I ended up buying an aftermarket GRP one, and I've had no bother.
The last post was made 2 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 43.21 Kb
