Hole/Split in tyre
DaddyStu
PostPosted: 14:49 - 11 Oct 2024    Post subject: Hole/Split in tyre Reply with quote
Noticed a 2cm wide deep slit in my rear tyre. Seems to be right through the tread to the base of the tread pattern. Opened it up a bit and filled it with loktite superglue. Only had that tyre on there for 4 months.
Do you guys repair or replace in such circumstances?
Daddystu
Zontes 125-G1 (part-ex'd). Yamaha Tracer 700.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:03 - 11 Oct 2024    Post subject: Reply with quote
Shocked
At least use rubber solution. Superglue is soluble (eventually) in water.
Triumph Sprint ST 1050
BanditsHigh
Worse than a woman
PostPosted: 15:04 - 11 Oct 2024    Post subject: Reply with quote
There's not a lot you could do to repair that, apart from maybe put a patch on the inside of the tyre to reinforce it slightly, in case it works it's way through.
I don't think superglue will last very long, you'd be better using some vulcanising glue (the type use to do puncture repairs) ... I think Thumbs Up
All the best ... Barry
DaddyStu
PostPosted: 15:14 - 11 Oct 2024    Post subject: Reply with quote
Yes, you're both right - I only had superglue available though.
Daddystu
blurredman
PostPosted: 07:37 - 15 Oct 2024    Post subject: Reply with quote
Pics?
The last post was made 2 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 44.51 Kb
