 Posted: 21:05 - 11 Feb 2024 Post subject: |
| P. wrote: |
Annoying re the kickstart, whats run in like for this? |
As far as i can make iut, it's take it reasonably easy for 200 miles while running it on a higher premix ration (20:1). Then de-coke it, throw away the head gasket and drop the premix back to 25:1.
Made it to the dragon rally this weekend and I've done my 200 miles. It ran as expected, I was topping out at about 45mph, the thing is dog slow. It ran really well the whole way and perfect weather for the job, single digit air temperature with a constant high humidity so plenty of charge cooling effect and high air density.
There is an odd "misss" which it does in top gear only at exactly 36mph and only the first time you pass that speed after hooking 4th. I think it may be some oddity of the gearbox alignment. Oher than that, it never missed a beat, starts 3rd kick and runs like a sewing machine. The speedo shat the bed already which was not entirely unexpected and both shocks have leaked their oil out but given they are nearly 30 years old and have spent more than 20 sitting in a shed, I'll let them off.
It was running noticeably better on the way home, climbing hills better especially. Once the premix is dropped down and the compression is bumped up by the head gasket removal, it should find a bit more power. I can have a fiddle with the timing too and see if that'll dial in a bit better. Oh, and it's weeping a little oil past the gearbox cover which is unsurirising since I removed it and refitted it with the old gasket and in something of a rush.
I think the voltage delivery is really dirty, I'm going to have a look out for an oscilloscope, I've been wanting one for a bit. I suspect the reg/rec is not everything it should be, the electronic flasher relay had a tantrum a couple of times.
Overall very pleased. It's been a hell of a shakedown run and it's been to two rallies loaded up with camping gear already.
Got my pint off Virus. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| virus |
 virus World Chat Champion
| A100man |
 A100man World Chat Champion
 Posted: 09:38 - 12 Feb 2024 Post subject: |
| stinkwheel wrote: |
Got my pint off Virus. |
Hats off- bloody good effort. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| P.addy |
 P.addy Red Rocket
| WD Forte |
 WD Forte World Chat Champion
 Posted: 17:44 - 12 Feb 2024 Post subject: |
Well really!
You'd think he'd at least wear a tie to these social events
Makes you wonder what end of the social scale these people belong..
https://www.bikechatforums.com/download.php?id=106648 ____________________ bikers smell of wee |
| virus |
 Posted: 18:01 - 12 Feb 2024 Post subject: |
I must say, Scotts habit of wearing a vibrant hawaiian shirt really helps find him in a crowd on account of not looking like every other big bloke with a jacket and waistcoat  ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
 Posted: 18:07 - 12 Feb 2024 Post subject: |
I was wearing a pair of black tracksuit bottoms with white stripes up the legs as befits the origins of the bike but they had got heavily muddy from walking up the camping field and, frankly, it was too hot. I was genuinely wearing a hawaiian shirt and floppy hat because they were appropriate for the weather conditions at the time. It got chillier once the sun went down mind. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| that_impulse_guy |
 that_impulse_guy Scooby Slapper
 Posted: 11:52 - 13 Feb 2024 Post subject: |
you dont need my praise, but as a mostly silent follower of this thread since november I'm pretty impressed you went out on a run and got back ok already, all this from some bits in boxes a few months ago. Nice job. ____________________ Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R |
 Posted: 18:48 - 15 Feb 2024 Post subject: |
Thought I'd have a look at the electrics today. Did a static test of the coil windings which gave an equal resistance to earth on both sides and an acceptable coil resistance between the two.
Static unregulated output was sitting at about 25VAC at idle.
On my analogue meter, the regulated output was a slight waver up and down at around the 14V point as you'd expect. I tried it with the digital meter and it was absolutely all over the place, couldn't settle on a reading and was flickering up into the 100+V range then back down again. Tried it on AC and it was also giving a wildly fluctuating reading.
I think the reg/rec is junk. I managed to score a used YZFR1 reg/rec on ebay for £35 which is a shendingen mosfet type (FH16 I think) and the proper connectors on amazon for £7.50. I think this will be a good starter for 10, see what it does with that. Even if more needs doing, it's not wrong to have it.
Also scored a pair of used shocks off somethingorother for £35. They look right and the dimensions are correct. Seller had no idea what they were off either so it's down to a lottery if the spring rate is in the right ballpark. Only bikes I've seen with shocks this length are either 125s or harleys and they certainly aren't beefy enough for a harley. The springs are progressive which is probably a good thing for my weight on a tiny bike. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
 Posted: 20:21 - 15 Feb 2024 Post subject: |
Difficult to see what's exactly what on forum posts
and I miss stuff anyway
but have you got each coil grounded one side and tother's going to the RR?
if so that would be 2 half waves and a bit spiky I reckon
I'd probably first have tried lifting both wires from each coil and joined them in the middle as one connection ( no connections to ground)
then used that and each of the free end wires to connect into a common
3 phase bike RR
maybe you already did that, dunno
just did a quick scrawl on the white-ish board
i'd have tried the bottom version first
https://imgur.com/FbvcSTB.jpg[/img] ____________________ bikers smell of wee |
 Posted: 22:37 - 15 Feb 2024 Post subject: |
| WD Forte wrote: | Difficult to see what's exactly what on forum posts
3 phase bike RR
https://imgur.com/FbvcSTB.jpg[/img] |
It's a wee bit more spohisticated than that. There are two output wires but multiple coils/windings in a star pattern, 8 in total but I think the top one is for the spark because it's associated with the hall effect sensor. Both wires do connect to earth (I checked, equal resistance) then feed into a standard single phase shunt type reg/rec.
Something to go at though. I think it should be possible to lift the earths (green wires) as long as I can work out which are to the charging coil and which are to the ignition. I'd have thought with that many coil stacks, output should be relatively clean. It's not dis-similar to the setup on the lucas alternator on my enfield which runs LEDs fine. I'm deeply suspicious of this reg/rec so I'll try swapping that out first which is a very easy job and see how it flies. If no beans, I'll have a poke at the stator.
https://lh3.googleusercontent.com/pw/ABLVV87tzr7JuF1r8drV345xeP0KBsFlKTznGpCNXIKjhRpPCijaRDo1ENBk782EJ6uF4dA9sRQslnkl-HEbMfsXuY5f8rHvvvGiOcuELjx6U7QlLqop8k5EhscmkFAF7jDXPTQ_YN3zViYUW5fTda--UY57=w1547-h870-s-no ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
There is a gap of 195 days between these two posts... |
| MarJay |
 MarJay But it's British!
| A100man |
 Posted: 14:44 - 02 Sep 2024 Post subject: |
Awesome..
..now will one fit my A100 ( 50 x50 mm B/S)  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| MarJay |
| blurredman |
 Posted: 14:49 - 02 Sep 2024 Post subject: |
It might not make any difference but make your ears bleed.  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| MarJay |
 Posted: 17:41 - 16 Sep 2024 Post subject: |
I found this pic the other day...
https://www.bikechatforums.com/files/dsc02021.jpg ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
 Posted: 10:53 - 17 Oct 2024 Post subject: |
Well, the exhaust bolted right on with a very simple bracket. It rode fine, not much different to the original one in fairness.
Out of curiosity, I decided to take the end can apart to see what was going on in there. Turns out it's literally a metal cylinder stuffed with fibreglass packing. Doesn't even have a baffle tube in there, there's just a long spring to stop the fibregalss from completely obstructing the gas exiting.
So no stinger on the end of the expansion chamber and a surprisingly wide exhaust diameter. I decided to make a baffle tube. Used a piece of alloy tube, necked it down with a steel insert at the exit from the expansion chamber so the diameter is the same as the standard, then a 12cm stinger section then perforated the rest of the way. All bolted back together easily with the packing round the outside of the baffle tube.
Immediate transformation. Crisp, rattly exhaust note which I associate with a properly setup 2t exhaust. Way quicker off the throttle, fewer "bung-bungs" on the overrun which means it's scavenging well. Had to wind in the idle screw significantly so it might need a larger pilot but frankly, it hardly ever uses low revs unless you're stopped in traffic and the idle is very stable. Picks up well from no revs and pulls much better through the midrange, I can stay in top gear up hills I was having to downshift for previously.
It would probably stand an extra tooth on the front sprocket now, although I might do some light offroading on this bike becuse it's very capable on dirt so I'll probably just leave it as-is.
A plug chop showed a nice clean, brown electrode but I tried the next jet size up just to see. That was too much main, caused it to bog between 3/4 and full throttle unless it was absolutely flat-out so went right back to standard jetting.
Saw 50mph on it, which is a first. Money well spent, although the standard setup on that exhaust was very shonky. I'm guessing it's for noise reasons because it is a tad on the loud side now. Probably not enough to have people tutting as you ride past but if you were doing laps of the town square all afternoon, I could see people getting annoyed.
The postman says he loves the smell coming out of my garage when he delivers the mail.
Did a short video.
https://youtu.be/V2Us1UyyGZk?si=WEw2JMF-HP8fFqmd ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| A100man |
 Posted: 11:04 - 17 Oct 2024 Post subject: |
| stinkwheel wrote: | Well, the exhaust bolted right on with a very simple bracket. It rode fine, not much different to the original one in fairness.
Did a short video.
https://youtu.be/V2Us1UyyGZk?si=WEw2JMF-HP8fFqmd |
It sounds better than you do.. got a cold? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Easy-X |
 Easy-X Super Spammer
 Posted: 16:44 - 17 Oct 2024 Post subject: |
Sounds very nice  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| MarJay |
The last post was made 2 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
